Ir para o conteúdo principal
O que você precisa
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua Sidekick II, use o nosso manual de serviço.
  1. Sidekick II Teardown, Outer Casing: passo 1, imagem 1 %32
    • Use the plastic opening tool to remove the 4 buttons on each corner of the Sidekick.
    • Gently pry open button and remove button.
    • Do this for each of the 3 buttons remaining.
  2. Sidekick II Teardown: passo 2, imagem 1 %32 Sidekick II Teardown: passo 2, imagem 2 %32
    • The bumpers on the top and bottom of the phone can be removed by simply "peeling" them off.
  3. Sidekick II Teardown: passo 3, imagem 1 %32
    • Use the T6 Torx Screwdriver to remove the 4 screws that are underneath the 4 buttons you removed in step one.
  4. Sidekick II Teardown: passo 4, imagem 1 %32
    • Flip the screen up halfway (90 degrees), to reveal the 2 screws above the right side of the keyboard.
    • Use the Torx 6 screwdriver to remove these 2 screws.
    • Be careful in handling the phone after removing the screws, because the two main bodies of the phone are no longer attached.
  5. Sidekick II Teardown: passo 5, imagem 1 %32
    • After removing the 6 screws and both bumpers, the phone will be easy to separate into the two main bodies.
    • You can use your hands to simply pull apart the top casing from the bottom casing.
  6. Sidekick II Teardown, Sidekick II Teardown: passo 6, imagem 1 %32 Sidekick II Teardown, Sidekick II Teardown: passo 6, imagem 2 %32
    • Remove screen from casing.
  7. Sidekick II Teardown: passo 7, imagem 1 %32 Sidekick II Teardown: passo 7, imagem 2 %32
    • Remove 4 screws from back of screen using Torx 6 Screwdriver.
    • Pry screen out of casing using fingers.
  8. Sidekick II Teardown: passo 8, imagem 1 %32 Sidekick II Teardown: passo 8, imagem 2 %32 Sidekick II Teardown: passo 8, imagem 3 %32
    • Remove 4 screws from front of screen with Phillip screwdrivers.
    • Peel off the metal covering on the back of the screen.
    • Be careful when taking off the metal covering. The orange ribbon will not come out all the way, and it is fragile.
  9. Sidekick II Teardown: passo 9, imagem 1 %32
    • Remove the protective cover in front of the screen.
    • Do not use metal tools, you may damage the protective cover or the screen. Use your fingers only.
  10. Sidekick II Teardown: passo 10, imagem 1 %32 Sidekick II Teardown: passo 10, imagem 2 %32
    • Take the screws out using the Torx 6 screwdriver.
    • Then lift the thumb wheel and housing off of the front panel.
  11. Sidekick II Teardown: passo 11, imagem 1 %32 Sidekick II Teardown: passo 11, imagem 2 %32
    • Remove 2 black "rivets" from back of casing with the plastic opening tool.
    • Press keyboard out of front of casing using thumbs. Don't press too hard as you may break the board.
  12. Sidekick II Teardown: passo 12, imagem 1 %32 Sidekick II Teardown: passo 12, imagem 2 %32
    • Remove the 5 black screws with a Phillips head screwdriver.
    • Lift the bottom of the control board from housing, and separate the two.
  13. Sidekick II Teardown: passo 13, imagem 1 %32
    • Carefully remove battery and back plate.
    • Do not use metal tools, you may damage the control board. Use only your fingers.
  14. Sidekick II Teardown: passo 14, imagem 1 %32
    • Here are all of the pieces that you have disassembled
michael albaum
Membro desde: 01/20/10
87 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 3-19, Maness Winter 2010 Membro de Cal Poly, Team 3-19, Maness Winter 2010
CPSU-MANESS-W10S3G19
Membros da 4
Autoria de 11 guias
Um comentário
nice job from a former geek
Jared Boies - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 34
Duração total: 7,336
