O que você precisa
This is a small game but still surprisingly fun... but not enough to keep me from tearing it down!
This was held together by only one Phillips screw. So far so good.
Battery was a CR2032, which seems to be a common choice for this type/size of device
The speaker is in the bottom-right hand corner, with the reset switch above it.
On the back side of the motherboard, we see the battery contacts in the upper-left hand corner, and the four screws that hold the display to the front.
After removing three of the screws, I found that the one holding down the bottom-left corner of the display was stripped, forcing me to cut and rotate the corner away.
After that however, it just dropped right off.
The display is just a simple black and white LCD.
2 comentários
Very cool, great teardown!!
