Introdução
This IDES2323 Task2 teardown assignment was done by industrial design student Yuanhang Yan. The item disassembled is the Schick - Hydro 5 Groomer Kit for Men, 4-In-1 Power Trimmer. This post will go into detail about the inner workings of this Groomer Kit.
O que você precisa
The box contains: AA battery, four replacement razor heads, GroomerKit.
Simply pull the top and bottom of the GroomerKit apart to open it.
The Shaver Part has a replaceable Razor head, just press the white button on the front and the Razor head comes off automatically.
Open the battery compartment of the Shaver Part begins with cutting the outer wrapping of silicone along the red line with a knife.
After removing the silicone layer you will see the internal battery compartment structure, next you just need to use a screwdriver to press down the metal part inside the red circle to remove the battery compartment smoothly.
The protective part of the Trimming part simply comes off by pushing your thumb along the red line position.
The blade part of the Trimming part simply comes off by pushing your thumb along the red line position.
The position shown by the circle in the picture is where the output of the motor is located, and this metal bar will always make a clockwise movement.
Open the Trimming Part begins with cutting the outer wrapping of silicone along the red line with a knife.
Once you open the silicone skin you can see the circuit board part of the button.
Since I couldn't open the inner structure, I drew pictures of the inner structure.
