Ir para o conteúdo principal
Ferramentas utilizadas neste teardown
Introdução
Teardown of an early 1980s Sanyo CX-110 calculator.
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua Sanyo CX 110, use o nosso manual de serviço.
  1. Now that we removed the back of the calculator, here are the battery and the back of the circuit board. Sanyo Tight-Seal Power-Up Sum-3 1.5V AA battery.
    • Now that we removed the back of the calculator, here are the battery and the back of the circuit board.
    • Sanyo Tight-Seal Power-Up Sum-3 1.5V AA battery.
    • Positive contact for the battery.
    • Negative contact for the battery.
  2. After removing the seven Phillips screws and flipping the circuit board, you will see the "brain" of the calculator—a Sanyo LI3120M chip.
    • After removing the seven Phillips screws and flipping the circuit board, you will see the "brain" of the calculator—a Sanyo LI3120M chip.
    • The keypad has been removed from the calculator.
  3. Now that we have completed the teardown, we can lay out all the parts of the calculator.
    • Now that we have completed the teardown, we can lay out all the parts of the calculator.
    • The AA battery.
    • Parts of the LCD display.
    • The circuit board.
    • The keypad containing all the buttons of the calculator.
    • The housing for the calculator.
samhnri
Membro desde: 07/04/2010
415 Reputação
2 Guias de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 5,216
