Ir para o conteúdo principal
O que você precisa
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua Sandisk Sansa m230 Series mp3 player, use o nosso manual de serviço.
  1. Sandisk Sansa m230 Series mp3 player Teardown, Sandisk Sansa m230 Series mp3 player Teardown: passo 1, imagem 1 %32
    • Remove the battery compartment cover.
    • Remove the battery.
  2. Sandisk Sansa m230 Series mp3 player Teardown: passo 2, imagem 1 %32
    • Locate and remove the screw next to the battery compartment lid.
  3. Sandisk Sansa m230 Series mp3 player Teardown: passo 3, imagem 1 %32
    • Locate the interlocking pegs along the seam of the device's casings.
    • Gently pry the pegs apart one at a time, working your way around the case.
    • Be careful when prying apart the pegs: they are made of plastic and may break.
  4. Sandisk Sansa m230 Series mp3 player Teardown: passo 4, imagem 1 %32
    • The battery contact springs may prevent the case from separating.
    • Push the battery contact springs down through the hole in the case.
  5. Sandisk Sansa m230 Series mp3 player Teardown: passo 5, imagem 1 %32
    • The casing protecting the USB and headphone jacks must be removed.
    • Locate and gently pry apart the two interlocking clips holding it in place.
    • The outer casings may now be removed and the MP3 player should separate.
  6. Sandisk Sansa m230 Series mp3 player Teardown: passo 6, imagem 1 %32
    • You now have access to all components found on the inside of the device!
James Thorne
Membro desde: 11/05/13
665 Reputação
Autoria de 6 guias
Equipe
UMass Dartmouth, Team 1-8, Shastany Fall 2013 Membro de UMass Dartmouth, Team 1-8, Shastany Fall 2013
UMASSD-SHASTANY-F13S1G8
Membros da 3
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 15
Duração total: 2,886
