Ir para o conteúdo principal
O que você precisa
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua Samsung T139, use o nosso manual de serviço.
  1. Samsung T139 Teardown, Removing the battery and back screws: passo 1, imagem 1 %32 Samsung T139 Teardown, Removing the battery and back screws: passo 1, imagem 2 %32
    • Start by removing the back of the phone. Once that is done you will find 4 Phillips 00 screws two on the top left and right and two on the bottom left and right
    • Take out the battery
  2. Samsung T139 Teardown, Remove the back screws: passo 2, imagem 1 %32
    • You will see 4 phillips 00 screws, two on the top left and right and two on the bottom left and right. Remove them.
  3. Samsung T139 Teardown, Removing the outer border: passo 3, imagem 1 %32 Samsung T139 Teardown, Removing the outer border: passo 3, imagem 2 %32 Samsung T139 Teardown, Removing the outer border: passo 3, imagem 3 %32
    Ferramenta utilizada neste passo:
    Jimmy
    $7.95
    • Take the Jimmy and go around the sides of the phone until the outer border comes off.
    • Be aware of the buttons on the side as they will fall out.
  4. Samsung T139 Teardown, Removing the logic board: passo 4, imagem 1 %32 Samsung T139 Teardown, Removing the logic board: passo 4, imagem 2 %32
    Spudger
    $2.99
    • Push gently on the side of the screen cable with a Spudger to release
    • Then remove the logic board.
  5. Samsung T139 Teardown, Removing the key pad: passo 5, imagem 1 %32
    • Take the keyboard out by pulling gently on the side with some tweezers
  6. Samsung T139 Teardown, Remove screws: passo 6, imagem 1 %32 Samsung T139 Teardown, Remove screws: passo 6, imagem 2 %32
    • Remove the two black screw covers on the bottom of the screen
    • Remove the two screws that are revealed
  7. Samsung T139 Teardown, Removing the case: passo 7, imagem 1 %32 Samsung T139 Teardown, Removing the case: passo 7, imagem 2 %32
    Jimmy
    $7.95
    • Take a Jimmy and go around it until the front case (the one with the smaller screen) comes off.
  8. Samsung T139 Teardown, Looking at the phone: passo 8, imagem 1 %32
    • After you are done with step six the phone should look like this
  9. Samsung T139 Teardown, Remove the logic board to screen connection: passo 9, imagem 1 %32 Samsung T139 Teardown, Remove the logic board to screen connection: passo 9, imagem 2 %32 Samsung T139 Teardown, Remove the logic board to screen connection: passo 9, imagem 3 %32
    Spudger
    $2.99
    • Take a Spudger and push up on the little black bar at the top end of the screen to logic board cable
  10. Samsung T139 Teardown, Remove the camera: passo 10, imagem 1 %32
    Spudger
    $2.99
    • Take a Spudger and push up the little red bar over the camera cable.
    • Pull the cable out and remove the camera.
  11. Samsung T139 Teardown, Getting the screen out: passo 11, imagem 1 %32
    • Take a pair of tweezers and lift up to remove the screen.
  12. Samsung T139 Teardown, The finished product: passo 12, imagem 1 %32
    • Congrats! Your done. Let's take a look at what we have.
    • Outer cases
    • Screens
    • Logic board
    • A camera
    • Some button covers
    • A battery
    • A keypad cover
Nathan
Membro desde: 09/21/17
386 Reputação
Autoria de 2 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 457
