Ir para o conteúdo principal
O que você precisa
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua Samsung SPH-A660, use o nosso manual de serviço.
  1. Samsung SPH-A660 Teardown, Samsung SPH-A660 Teardown: passo 1, imagem 1 %32 Samsung SPH-A660 Teardown, Samsung SPH-A660 Teardown: passo 1, imagem 2 %32
    • The Samsung SPH-A660 Cell Phone.
  2. Samsung SPH-A660 Teardown: passo 2, imagem 1 %32 Samsung SPH-A660 Teardown: passo 2, imagem 2 %32 Samsung SPH-A660 Teardown: passo 2, imagem 3 %32
    • Slide the grey tab foreward and pry the battery up and out of the phone.
  3. Samsung SPH-A660 Teardown: passo 3, imagem 1 %32 Samsung SPH-A660 Teardown: passo 3, imagem 2 %32
    • Once the battery pack is removed from the phone, remove indicated screws.
    • Bend back the antenna to access the left middle screw.
  4. Samsung SPH-A660 Teardown: passo 4, imagem 1 %32 Samsung SPH-A660 Teardown: passo 4, imagem 2 %32 Samsung SPH-A660 Teardown: passo 4, imagem 3 %32
    • Insert the plastic opening tool into the slot that runs along the side of the phone. Slowly pry open the phone by working your way around the edges.
    • There are tabs which hold the phone together and you may need force to pry the phone apart.
    • During this step, the side volume key may fall out; this is okay.
  5. Samsung SPH-A660 Teardown: passo 5, imagem 1 %32
    • Carefully remove the highlited connector between the logic board and the screen by using either your fingers or plastic opening tool.
    • Lift up on the tabbed connector to remove it.
  6. Samsung SPH-A660 Teardown: passo 6, imagem 1 %32 Samsung SPH-A660 Teardown: passo 6, imagem 2 %32 Samsung SPH-A660 Teardown: passo 6, imagem 3 %32
    • Remove the logic board from the phone by gently lifting up on the large green logic board with the plastic opening tool.
  7. Samsung SPH-A660 Teardown: passo 7, imagem 1 %32 Samsung SPH-A660 Teardown: passo 7, imagem 2 %32 Samsung SPH-A660 Teardown: passo 7, imagem 3 %32
    • Remove the keypad from the body by grasping the white rubbery pad and lifting it off the phone.
  8. Samsung SPH-A660 Teardown: passo 8, imagem 1 %32 Samsung SPH-A660 Teardown: passo 8, imagem 2 %32
    • Remove the two sticky covers by using a flat edge to pry off the stickers in order to gain access to the screws.
    • Slide the edge under the stickers and they should come off with relative ease.
  9. Samsung SPH-A660 Teardown: passo 9, imagem 1 %32 Samsung SPH-A660 Teardown: passo 9, imagem 2 %32
    • Remove the two highlited screws from the phone below the screen in order to open the display area.
  10. Samsung SPH-A660 Teardown: passo 10, imagem 1 %32 Samsung SPH-A660 Teardown: passo 10, imagem 2 %32
    • Pry the phone display open by inserting a plastic opening tool into the crack that runs along the side of the phone display under the screws.
    • Once you have the display cover wedged open, use your fingers to pry the whole cover off the phone.
    • Some force may be needed to remove the cover, as several tabs are there which hold the two parts in place. Therefore, be careful when prying the cover apart
  11. Samsung SPH-A660 Teardown: passo 11, imagem 1 %32 Samsung SPH-A660 Teardown: passo 11, imagem 2 %32 Samsung SPH-A660 Teardown: passo 11, imagem 3 %32
    • Be Extremely Careful in this next step as if you pry the hinge off too fast you may rip the connector between the logic board and screen.
    • Carefully wedge a plastic opening tool between the hinge on the body as shown in the highlited area in picture two. (be sure to insert the wedge into the right hinge when looking down onto the phone as in the picture).
    • Slowly pry the hinge off the body as shown in the third picture and set the phone down when you get to this step.
    • Next slide the connector cable out of the slot on the back side of the phone and the screen will be disconnected from the key pad body.
  12. Samsung SPH-A660 Teardown: passo 12, imagem 1 %32 Samsung SPH-A660 Teardown: passo 12, imagem 2 %32 Samsung SPH-A660 Teardown: passo 12, imagem 3 %32
    • Next use a plastic opening tool to pry the screen from the cell phone cover.
  13. Samsung SPH-A660 Teardown: passo 13, imagem 1 %32 Samsung SPH-A660 Teardown: passo 13, imagem 2 %32
    • Congratulations!!! You have successfully disassebled the Samsung SPH-A660
    • Outer Casing
    • Phone Top Cover
    • LCD Screen
    • Logic Board
    • Phone Back
    • Battery
    • Keypad
Mike Buerli
Membro desde: 01/22/10
4 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 13-26, Maness Winter 2010 Membro de Cal Poly, Team 13-26, Maness Winter 2010
CPSU-MANESS-W10S13G26
3 Membros
Autoria de 10 guias
1Comentário do guia
Where is the microphone located?
Glenn - Responder
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 24
Ao todo: 6,228
