Ir para o conteúdo principal
Este teardown está em andamento – Atualizar periodicamente para ver as últimas alterações!
O que você precisa
  1. Samsung SGH-A777 Teardown, Samsung SGH-A777 Teardown: passo 1, imagem 1 %32
    • The Samsung SGH A777
  2. Samsung SGH-A777 Teardown: passo 2, imagem 1 %32 Samsung SGH-A777 Teardown: passo 2, imagem 2 %32 Samsung SGH-A777 Teardown: passo 2, imagem 3 %32
    • Remove the black cover by sliding up.
    • Remove the SIM card(not shown) and battery.
  3. Samsung SGH-A777 Teardown, Removing the back cover: passo 3, imagem 1 %32 Samsung SGH-A777 Teardown, Removing the back cover: passo 3, imagem 2 %32 Samsung SGH-A777 Teardown, Removing the back cover: passo 3, imagem 3 %32
    • Remove the six Phillips head screws. Keep track of their position.
    • Using a SIM removal tool or other small point, remove the bottom antenna cover. See photo 2. Place the tool in the bottom right corner and pry it off.
    • Using a spudger, carefully remove the antenna cover. Remove the two screws.
  4. Samsung SGH-A777 Teardown, Remove the back cover: passo 4, imagem 1 %32 Samsung SGH-A777 Teardown, Remove the back cover: passo 4, imagem 2 %32
    • Using a spudger pry the back cover off carefully.
    • Using your fingers or a spudger remove the two side buttons. Note their positions. These should easily pop off.
  5. Samsung SGH-A777 Teardown, Remove more screws: passo 6, imagem 1 %32 Samsung SGH-A777 Teardown, Remove more screws: passo 6, imagem 2 %32 Samsung SGH-A777 Teardown, Remove more screws: passo 6, imagem 3 %32
    • Remove the two screws surrounding the camera.
    • Remove the two screws around the top of the battery spot.
    • Pry the black midplate off the phone.
    • Be careful as the screen is connected still by a ribbon cable.
    • Remove the entire Samsung model number sticker.
    • Slide the metal sliding mechanism up.
    • Remove the two screws.
  6. Samsung SGH-A777 Teardown, Separating the screen assembly: passo 8, imagem 1 %32 Samsung SGH-A777 Teardown, Separating the screen assembly: passo 8, imagem 2 %32
    • Carefully flip the motherboard up. Flip it from bottom to top.
    • Disconnect the ribbon cable with a spudger.
  7. Samsung SGH-A777 Teardown, Removing the backplate for the screen: passo 9, imagem 1 %32
    • Pry starting at the bottom with a spudger. Remove the cover. This will require some force and a guitar pick.
  8. Samsung SGH-A777 Teardown, Remove the camera assembly: passo 10, imagem 1 %32
    • Remove the daughter board and lift the small blue flex cable from the back of the LCD.
    • Remove just enough of the blue sticker to disconnect the orange flex cable. Flick the brown connector up and remove.
    • Remove the camera assembly.
  9. Samsung SGH-A777 Teardown, Remove the LCD: passo 11, imagem 1 %32 Samsung SGH-A777 Teardown, Remove the LCD: passo 11, imagem 2 %32
    • Using a guitar pick, carefully pry up the LCD shield plate from the sides.
    • Be careful not to crack the LCD. Don't touch the LCD!
    • Use a spudger edge around the edges of the lens. Remove carefully and use 3M to reattach.
  10. Samsung SGH-A777 Teardown, To remove motherboard:: passo 13, imagem 1 %32
    • Flick the little brown connector up and remove the orange flex cable.
Josh Bacon
Membro desde: 03/02/15
151 Reputação
Autoria de 3 guias
Um comentário
My cell phone SGH a777 has lost the sound and how to correct an entry does not function.
I want to have it repaired. Where should I bring it to have it repaired?
Vicente Paladin Molar - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 4
Duração total: 1,981
