Ir para o conteúdo principal
O que você precisa
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua Samsung SCH-U340, use o nosso manual de serviço.
  1. Samsung SCH-U340 Teardown, Samsung SCH-U340 Teardown: passo 1, imagem 1 %32
    • The U340's outer casing is held in place through a combination of screws and tabs. The screws are hidden under plastic plugs, which will need to be removed.
  2. Samsung SCH-U340 Teardown: passo 2, imagem 1 %32
    • After these plugs are pulled out, remove the two screws located under them. These screws are very small, so be sure to keep them safe.
  3. Samsung SCH-U340 Teardown: passo 3, imagem 1 %32
    • The only thing keeping the top part of the casing on now are seven tabs--one large tab (marked in red) and six smaller tabs (marked in yellow). To remove the casing, first start by removing the big tab.
  4. Samsung SCH-U340 Teardown: passo 4, imagem 1 %32
    • Now remove the smaller tabs, doing the tabs marked in red last. After the tabs have been removed, carefully peel the outer cover off completely.
  5. Samsung SCH-U340 Teardown: passo 5, imagem 1 %32
    • Removing the bottom cover is a much simpler task. After removing the four screws marked in the picture, simply peel the back cover off.
Anish Sambamurthy
Membro desde: 02/11/10
29 Reputação
Autoria de 1 guia
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 7
Ao todo: 1,040
