Ir para o conteúdo principal
O que você precisa
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua Samsung Jitterbug, use o nosso manual de serviço.
  1. Samsung Jitterbug Teardown, Samsung Jitterbug Teardown: passo 1, imagem 1 %32 Samsung Jitterbug Teardown, Samsung Jitterbug Teardown: passo 1, imagem 2 %32 Samsung Jitterbug Teardown, Samsung Jitterbug Teardown: passo 1, imagem 3 %32
    • First remove the battery and rubber feet from base and under phone number inside.
    • Undo all six screws. Only the two under the battery will come out fully.
  2. Samsung Jitterbug Teardown: passo 2, imagem 1 %32 Samsung Jitterbug Teardown: passo 2, imagem 2 %32
    • Pop the six clips indicated in green and remove back. I removed the two on the sides first, but it was a huge pain to open the rest of the way. I suggest starting from the top four.
    • Blue is the connector to the screen and speaker board in the top of the phone.
    • Purple is the chip and orange is charging port.
    • The opposite side of the board (not pictured) has the microphone on it, it's a small black round bump on the bottom.
  3. Samsung Jitterbug Teardown: passo 3, imagem 1 %32 Samsung Jitterbug Teardown: passo 3, imagem 2 %32 Samsung Jitterbug Teardown: passo 3, imagem 3 %32
    • Unhook screen connector and pop out board (just put a screwdriver under and pop).
    • Peel off button pad.
  4. Samsung Jitterbug Teardown: passo 4, imagem 1 %32 Samsung Jitterbug Teardown: passo 4, imagem 2 %32 Samsung Jitterbug Teardown: passo 4, imagem 3 %32
    • Remove rubber front, then turn over.
    • Pop all five clips. Start at the top near the hinge and work down.
  5. Samsung Jitterbug Teardown: passo 5, imagem 1 %32 Samsung Jitterbug Teardown: passo 5, imagem 2 %32 Samsung Jitterbug Teardown: passo 5, imagem 3 %32
    • Blue is main screen and mini screen board. Green is button and underneath is the main speaker. Purple is
    • Pop out all pieces. Be careful not to break the cabling connecting the outer bits to the board.
Kari Fox
Membro desde: 06/24/13
125 Reputação
Autoria de 1 guia
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 10
Ao todo: 2,179
