Ir para o conteúdo principal
O que você precisa
Vídeo de Apresentação
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua Samsung Gear Live, use o nosso manual de serviço.
  1. Samsung Gear Live Teardown, Samsung Gear Live Teardown: passo 1, imagem 1 %32 Samsung Gear Live Teardown, Samsung Gear Live Teardown: passo 1, imagem 2 %32
    • We could very well be witnessing the birth of the smartwatch revolution. Google has unleashed not one, not two, but three smartwatches onto the battlefield. We have before us the Gear Live of those three fabled smartwatches.
    • The official tech specs:
    • 1.63” Super AMOLED display with a resolution of 320 x 320 pixels (278 ppi)
    • 1.2 GHz processor
    • 300 mAh Battery (rated at max 1 day of usage)
    • 4 GB internal flash storage with 512 MB RAM
    • Digital compass, accelerometer, gyroscope, heart rate monitor
    • Bluetooth 4.0 Low Energy
  2. Samsung Gear Live Teardown: passo 2, imagem 1 %32 Samsung Gear Live Teardown: passo 2, imagem 2 %32 Samsung Gear Live Teardown: passo 2, imagem 3 %32
    • Taking a page out of the "If it ain't broke, don't fix it" book, the new Gear Live looks eerily similar to the Samsung Gear 2 we took apart back in April.
    • This will warrant more than a few comparisons between the two—after all, you don't want to buy the wrong smartwatch, arewerite?
    • If your smartwatch was ever arrested, would you be able to identify it out of a police lineup of smartwatches?
    • Left to right we have the Samsung Gear 2, Samsung Gear Fit, LG G Watch, and Samsung Gear Live.
  3. Samsung Gear Live Teardown: passo 3, imagem 1 %32
    • The bands come off in a snap. It's the same design geared towards replaceability as found in the Gear 2. A neat little pull lever disengages one of the holding pins, allowing the band to roam free from the watch.
    • The back of the smartwatch houses the heart rate monitor and reveals the true model number: SM-R382.
  4. Samsung Gear Live Teardown: passo 4, imagem 1 %32
    • Off come the Torx T5 screws found on the back of the Gear Live — the same type and size as in the LG G Watch.
    • Coincidence? We think so.
    • Unbeknownst to unsuspecting fixers—but knownst to us—these otherwise amiable T5 Torx screws are non-magnetic. Curses!
    • We've often seen a single non-magnetized screw in iPhones, near the digital compass—this may be a clever trick to avoid interference with the sensor.
    • Our best guess though, is that it was done to prevent Magneto or a metal bender from taking complete control of a Gear Live smartwatch.
  5. Samsung Gear Live Teardown: passo 6, imagem 1 %32 Samsung Gear Live Teardown: passo 6, imagem 2 %32 Samsung Gear Live Teardown: passo 6, imagem 3 %32
    • Screws removed, all you need to gain entry is a plastic opening tool to work around the perimeter—just like the Gear 2.
    • The Gear Live pops apart into two pieces — the front display assembly where all the magic happens, and the rear cover where the power lies.
  6. Samsung Gear Live Teardown: passo 7, imagem 1 %32 Samsung Gear Live Teardown: passo 7, imagem 2 %32 Samsung Gear Live Teardown: passo 7, imagem 3 %32
    • First off, let's take a peek at the Gear Live's battery.
    • We use a spudger to pry the lightly-adhered battery contact pad from its roost in the rear cover, and then use some sweet tweezers to pull the powerhouse out of the rear panel.
    • The battery inscription says "1.14 Wh." According to mathemagics and a 300 mAh battery, we conclude this watch runs on a fairly standard 3.8 V design.
  7. Samsung Gear Live Teardown: passo 8, imagem 1 %32 Samsung Gear Live Teardown: passo 8, imagem 2 %32 Samsung Gear Live Teardown: passo 8, imagem 3 %32
    • Next goes the power button ribbon cable. It was holding on like a champ for a while, but eventually our tweezers overtook it.
    • Hey, what's this? A Bluetooth / Wi-Fi antenna? This thing isn't supposed to have Wi-Fi! We don't know if Samsung is hiding anything for the future, but we are quite adept at reading cable inscriptions.
    • Also notable is the liquid damage indicator. So although this device is "IP67 water resistant," we don't necessarily recommend going into a pool with it.
  8. Samsung Gear Live Teardown: passo 9, imagem 1 %32 Samsung Gear Live Teardown: passo 9, imagem 2 %32 Samsung Gear Live Teardown: passo 9, imagem 3 %32
    • Next we focus our attention on the vibrator assembly. We definitely know this is the right vibrator inside, since the assembly also contains the Gear Live's SM-R382 model number.
    • This is also a limited-release vibrator motor — #449 of fifty billion produced.*
    • (*Our estimate based on no real knowledge of actual manufacturing numbers.)
  9. Samsung Gear Live Teardown: passo 10, imagem 1 %32 Samsung Gear Live Teardown: passo 10, imagem 2 %32
    • Next order of beeswax: we disconnect the display cable in order to get our hands on the motherboard.
    • The board comes out after a gentle nudge from our trusty tweezers.
    • The wee motherboard bears an even wee-er daughterboard layered right on top, where we find the power input connectors and the tiny biometric (heart rate) sensor.
  10. Samsung Gear Live Teardown: passo 11, imagem 1 %32 Samsung Gear Live Teardown: passo 11, imagem 2 %32
    • With a bit of patient spudgering, the boards are disengaged—leaving the motherboard stripped and primed for some primo IC analysis:
    • Maxim Integrated MAX77836 Low-Voltage Input, 3V/3.3V/5V/ Adjustable Output, Step-Up DC-DC Converter
    • Broadcom BCM4334W Bluetooth 4.0 / 802.11 a/b/g/n Wi-Fi / FM Receiver
    • STMicroelectronics STM32F401B ARM-Cortex M4 MCU with 128KB Flash
    • Samsung KMF5X0005A-A210 512 MB DRAM package with the Qualcomm APQ8026 System on Chip layered beneath
    • Qualcomm PM8226 power management IC
    • InvenSense MP92M 9-axis Gyro + Accelerometer + Compass
    • InvenSense ICS-43430 microphone
    Hello, there is some button or mode to physically boot the operating system. Thank you
    jorgealejandrocalle - Responder
  11. Samsung Gear Live Teardown: passo 12, imagem 1 %32 Samsung Gear Live Teardown: passo 12, imagem 2 %32 Samsung Gear Live Teardown: passo 12, imagem 3 %32
    • Happily, we're not yet done tweezing, because this little thermal pad needs some tweezing. Did we mention that "tweezing" is both useful and fun to say?
    • Beneath the thermal pad, a Cypress Semiconductor CYTMA545 touchscreen controller blinks its eyes under the bright lights of the teardown table.
    • Would that the display itself could also be tweezed. Sadly, it seems to be glued into the metal chassis.
  12. Samsung Gear Live Teardown: passo 13, imagem 1 %32 Samsung Gear Live Teardown: passo 13, imagem 2 %32
    • Samsung Gear Live Repairability Score: 8 out of 10 (10 is easiest to repair)
    • The band detaches readily, and more or less like a regular watch band—making replacements a simple, worry-free affair.
    • Despite the water-resistant construction, opening the case is no big deal. Bring your T5 driver and pry tools, but don't expect a fight.
    • The battery is readily accessed and replaced—with a friendly "Pull" tab to cheer you along.
    • Several small adhered-in flexible PCBs will present a challenge during repairs.
    • The fused display assembly, glued right into the chassis, makes screen replacement a dubious and costly proposition.
18 comentários
Is there a chip on the device that would support Wifi? What is more power friendly: BT 4.0 or Wifi? So many questions!
Tim - Responder
BT 4.0 is less enegy expensive
mpx220vomar -
What about the charging dock... it should get the same teardown treatment! :-)
Raphael Savina - Responder
where is the mic on this thing? the LG had a mic. also is there no speaker? what is the point if no speaker/mic??
Thomas - Responder
Just love teardowns! They are so cool!
Armen Orbelyan - Responder
BT and Wifi use the same range of frequencies so the antenna works for both, doesn't mean the watch has it.
Gabriel - Responder
Can you enable or add a wifi / bluetooth chip/antenna to the device though with soldering and such
Jay Dobbs -
What's the crystal made of--Gorilla Glass? Sapphire?
roebling - Responder
Does anyone have an estimation of the BOM ?
virginie - Responder
where can i buy parts? i googled and found nothing even on ebay.
i'm looking for a rear cover. mine cracked badly when i tried to snap on the charging piece
J S Xender - Responder
Did you find a parts supplier? I'm looking for the same thing. One of the charging contacts has disappeared!
Michael Fawcett -
Same here. Looking for a new plastic backing.
Nick Proszkow -
The voice commands started not to work properly. Now I have to scream besides the fone to use it. I tried a voice recorder app and realised that the mic volume is extremelly low (but it is working). Someone have an ideia of how to fix it? I opened the watch looking for something to clean, but I culdn't find. It appeared that it has a kind of foam protecting the mic hole (I believe it is because the IP67), but I was affraid of remove this foam.
Rafaello Perotto - Responder
Where can I fine a replacement back cover for the Gear Live? One of the little square charging contacts fell off of mine : (
Dan Someone - Responder
Did you find a solution? I have the same problem... :(
William Mann -
I have the same problem. Did you ever find a solution?
Jeff -
I had the same thing happen to my watch. I found a replacement charging connector on eBay. Took about two weeks to arrive, and I'm just about to tear the watch apart now.
Link here: http://www.ebay.com/itm/Original-Chargin...
Myron Pauls - Responder
Did it work just changing the piece? I have the same problem with my watch.
Erick -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 15
Duração total: 54,384
