Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Loja
Vídeo de Apresentação
Introdução
For iFixit's official Galaxy S6 teardown, click here. The guide you are currently viewing is retained for historical purposes only.
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua Samsung Galaxy S6, use o nosso manual de serviço.
  1. Power off the Samsung Galaxy S6.
    • Power off the Samsung Galaxy S6.
    • Use an eject pin or pointed tweezers to take out the SIM Card Tray.
  2. Heat up the Samsung Galaxy S6 Battery Door.
    • Heat up the Samsung Galaxy S6 Battery Door.
    • Draw the battery cover up with a suction cup. (Note: The battery door is adhered to the rear housing with quite strong adhesive, take your time during this process.)
    • Separate the battery door with an opening pick.
  3. Undo the 13 screws in the rear housing. Heat up the LCD Assembly.
    • Undo the 13 screws in the rear housing.
    • Heat up the LCD Assembly.
    • Separate the rear housing from the LCD Assembly with the help of suction cup tool and case opening tool. (Notice: be careful not to damage the wireless charging chip attached to the battery.)
    It’s often a PIN on your bootup screen unlock security will face a brand new SIM card with the owner of a brand new handset. Packaging materials http://dailycome.com/how-to-change-or-di...
    peetersuns - Responder
  4. Remove the power button flex. Remove the volume button flex. Remove the side keys. (Note: the Galaxy S6 power button and volume buttons are compatible with each other.)
    • Remove the power button flex.
    • Remove the volume button flex.
    • Remove the side keys. (Note: the Galaxy S6 power button and volume buttons are compatible with each other.)
    Excellent! !
    I’m attempting to replace the battery but the rear cover is not releasing. I’ve heated the back repeatedly but the glue is holding. Not sure how much heat can be used?
    Any suggestions?
    Thank you.
    Charles
    Charles Speake - Responder
    Slowly heat the back glass Edge more than 1 minutes, the adhesive is on the Edge of the phone. May this help you.
    Mandy - Responder
  5. Pry up the charging chip flex ribbons on both sides of rear housing. (Notice: be careful not to damage the flex ribbons.)
    • Pry up the charging chip flex ribbons on both sides of rear housing. (Notice: be careful not to damage the flex ribbons.)
  6. Pry up the LCD assembly connector, front facing camera connector, battery connector, ear speaker connector and home button flex ribbon connector.
    • Pry up the LCD assembly connector, front facing camera connector, battery connector, ear speaker connector and home button flex ribbon connector.
    • Turn over the motherboard and pry up the connector.
    I am more curious about the main board. Is there any in-depth description of component in main board?
    nelsonduann - Responder
  7. Gently pry up the battery with a spudger.
    • Gently pry up the battery with a spudger.
  8. Remove the front facing camera. Remove the ear speaker. (Notice: be careful not to break the flex ribbon.) Remove the vibrating motor.
    • Remove the front facing camera.
    • Remove the ear speaker. (Notice: be careful not to break the flex ribbon.)
    • Remove the vibrating motor.
  9. Remove the back facing camera on the mainboard. Remove the Bluetooth cable and Wi-Fi signal cable.
    • Remove the back facing camera on the mainboard.
    • Remove the Bluetooth cable and Wi-Fi signal cable.
  10. Undo the earphone jack screw. (Notice: the screw is different than the rear housing screws.) Heat up the LCD Assembly to release the front housing. Pry up the navigation light stickers.
    • Undo the earphone jack screw. (Notice: the screw is different than the rear housing screws.)
    • Heat up the LCD Assembly to release the front housing.
    • Pry up the navigation light stickers.
  11. Pry up the connector on the back side of home button.
    • Pry up the connector on the back side of home button.
    • Pry up the home button.
  12. The Samsung Galaxy S6 disassembly process is complete.
    • The Samsung Galaxy S6 disassembly process is complete.
    This, looks intense.
    Julio Velez - Responder
    It looked quite easy to me. BTW i don't think there was any glue on the front. It looks like it is built like say the galaxy s2 with the front lcd assembly snapped in to the back. Meaning calling it a mid frame is not all that accurate. The mid frame would be the bezel of a s3 s4 etc. Where as on this you have back/battery cover and the outer back glass. Which seems to basically be only edged glued. I know what they did to break the glass on the front. They tried to pull it apart s5 style not thinking there was screws holding it in can we say a oh crap moment :p
    Nova Flare - Responder
Mandy
Membro desde: 05/12/2014
9.188 Reputação
9 Guias de autoria
Thanks man i was curious what's inside that puppy... Not an easy repair like my galaxy s3....
Tear down s6 edge please
Mateusz - Responder
I'm curious, what is the DAC on this phone? I know Cirrus Logic partnered with Wolfson so it could be interesting to find out.
Mike Vercimak - Responder
The original author of this guide is ETrade Supply (as noted by the video itself). The video, images, and writeup were all produced and watermarked by them, though the image watermarks have since been removed via liberal cropping.
For the full and un-doctored photo set, please see:
http://www.etradesupply.com/blog/how-to-...
Chris Gilliam - Responder
Which image sensor did Samsung use for GS6? Is it SONY?
Will - Responder
Where is the memory located? And is it possible to upgrade it?
chris - Responder
Thanks for your great tutorial. I have a question though, if let says i wanted to replace broken piece (e.g. The motherboard or battery) where is the best place or website to go to.? I reside in perth, australia, so hoping if its overseas i still can get them posted here.
Thanks
N0MaD - Responder
I just broke the glass on the back camera. Looks like it is part of the back cover case. What part would i need to order to replace it?
Tony - Responder
I just broke the glass on the back camera. It is the glass on the back cover. What part do I need to replace that and where can I order it?
Tony - Responder
I am trying to locate the JTAG connections - any ideas? Thanks!
Will Jongenelen - Responder
Can the SIM card reader slot be removed from the logic board? Cuz my Galaxy 6 it's not reading my SIM card, thank you for the video
juarezdonan - Responder
My Galaxy s6 edge its was wet just on the mother board .
You think guys can I fix it and how thank you please let me know
Fernando - Responder
My Galaxy S6 Edge its was Wet On the top only 1/4 device can you guys help me to fix
Hello! on the back at middle frame. without NFC ribbon are 3 more ribbons one top left side...right side one...and bottom left side one.. its says ZF-E4 on them. What are them FOR? it's a problme if a broke one?
99Spyder99 - Responder
And i have a problem. Please help me...i changed the display on my galaxy s6...everything works ok..but when i assembly on the middle frame...and i charge..it's says it's charging but not charge..the battery ramins the same.? do you know what is the problem?
My phone fell face down, it has a protective screen on it, however, the impact from the fall knocked it out. It has a previous crack on the left bottom side. But since the fall, the screen went out. I can see it light up, it rings and all, but the screen is black. Is this something that I can repair myself?
Thanks
Wanda Wanda - Responder
Thanks for the video. I dropped S6 in the water sink and now battery gets hot very fast when I turn on. But I will NEVER going to buy another Samsung products again.
patricksingr - Responder
You dropped it in water and you blame the product . wow is all i can say
David -
Does anyone know what the little things on the inside of the housing along the edges do?
kyle - Responder
¡Excelente aporte muy bien realizado!
David Molina - Responder
Excellent! I may attempt to fix my GS6 now. After the Nougat OTA, my GS6 went black, would boot loop, go dead or not charge and was useless. I tried cache wipe, total reset, etc. but nothing worked. I discovered that if the phone were twisted slightly, that it would operate properly. Attached (twisted) to a board, it has been powered up now for eight hours and is still working perfectly with NO MALFUNCTIONS and is on the latest OS, Nougat 7.0 It has a poor connection internally!
Mr Horsepower - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 24
Últimos 30 dias: 126
Duração total: 139,142
