Ir para o conteúdo principal
O que você precisa
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua Samsung Galaxy S II, use o nosso manual de serviço.
  1. Samsung Galaxy S II Teardown, Samsung Galaxy S II Teardown: passo 1, imagem 1 %32 Samsung Galaxy S II Teardown, Samsung Galaxy S II Teardown: passo 1, imagem 2 %32 Samsung Galaxy S II Teardown, Samsung Galaxy S II Teardown: passo 1, imagem 3 %32
    • The 4.3-inch super Amoled Plus display is simply gorgeous!
    Pergunte ao FixBot
  2. Samsung Galaxy S II Teardown: passo 2, imagem 1 %32 Samsung Galaxy S II Teardown: passo 2, imagem 2 %32
    • Look at how slim the phone is! Only 8.49mm thin!
    • Back cover is flexible but don't worry it will not break. It also has a nice texture to it.
    Pergunte ao FixBot
  3. Samsung Galaxy S II Teardown: passo 3, imagem 1 %32
    • Look at how compact everything is inside!
    • Remove the seven visible screws.
    • Then unclip the back panel starting on the left next to the audio jack. Go slowly.
    Pergunte ao FixBot
  4. Samsung Galaxy S II Teardown: passo 4, imagem 1 %32 Samsung Galaxy S II Teardown: passo 4, imagem 2 %32 Samsung Galaxy S II Teardown: passo 4, imagem 3 %32
    • Removing the back panel gives you an impressive and sophisticated view of the internals.
    Pergunte ao FixBot
  5. Samsung Galaxy S II Teardown: passo 5, imagem 1 %32 Samsung Galaxy S II Teardown: passo 5, imagem 2 %32
    • Removing the motherboard is as simple as it looks !
    • Unclip the 5 ribbon connectors and the antenna cable.
    • Then remove the 2 small black screws.
    • Don't forget to unglue the volume flex and power flex, they are attached to the motherboard. Otherwise the motherboard won't come out easily like it should.
    Pergunte ao FixBot
  6. Samsung Galaxy S II Teardown: passo 6, imagem 1 %32 Samsung Galaxy S II Teardown: passo 6, imagem 2 %32 Samsung Galaxy S II Teardown: passo 6, imagem 3 %32
    • The board with removed EMI shields.
    • The front.
    • ..and the back.
    • The front panel without the logic board.
    • The front facing camera part, the cinch-vibrator-1.mic part and the usb connection-2.mic-antenna board.
    Pergunte ao FixBot
  7. Samsung Galaxy S II Teardown: passo 7, imagem 1 %32 Samsung Galaxy S II Teardown: passo 7, imagem 2 %32
    • The camera connector is at the upper left corner in the second picture.
    • The power and volume buttons are soldered to the logic board.
    • View the picture in HQ if you want to be impressed!
    Pergunte ao FixBot
  8. Samsung Galaxy S II Teardown: passo 8, imagem 1 %32
    • This EMI shield is nearly a heat sink.
    • Should be useful with a 1.2GHz dual core under it!
    Pergunte ao FixBot
  9. Samsung Galaxy S II Teardown: passo 9, imagem 1 %32 Samsung Galaxy S II Teardown: passo 9, imagem 2 %32 Samsung Galaxy S II Teardown: passo 9, imagem 3 %32
    • The (tiny) 8MP camera.
    • It's smaller than an iPhone 4 camera.
    Pergunte ao FixBot
  10. Samsung Galaxy S II Teardown: passo 10, imagem 1 %32 Samsung Galaxy S II Teardown: passo 10, imagem 2 %32
    • The front-facing camera and the light sensor are a single part.
    • The front-facing camera is 2MP, which is better than the iPhone 4's VGA camera.
    Pergunte ao FixBot
  11. Samsung Galaxy S II Teardown: passo 11, imagem 1 %32 Samsung Galaxy S II Teardown: passo 11, imagem 2 %32
    • The vibrator, first mic (did you know there are two?), cinch plug and the earspeaker.
    Pergunte ao FixBot
  12. Samsung Galaxy S II Teardown: passo 12, imagem 1 %32 Samsung Galaxy S II Teardown: passo 12, imagem 2 %32
    • The USB-connection and 2 x mic board.
    • It's stuck with glue to the front panel.
    • The (only) antenna cable and a metal shield holding the light sensor in place.
    Pergunte ao FixBot
  13. Samsung Galaxy S II Teardown: passo 13, imagem 1 %32 Samsung Galaxy S II Teardown: passo 13, imagem 2 %32
    • This is it.
    • It still works after reassembly!
    Pergunte ao FixBot
lon
Membro desde: 03/19/11
2.873 Reputação
Autoria de 2 guias
20Comentários do guia
Why not show the great display? =\
Diego Sampaio - Responder Compartilhar
Do you see the NFC module ? (the phone come frome England?)
Beacause there is a big disscution between ethier the NFC is not implemented on phone, maybe the chip is on ?
Forever TPC - Responder Compartilhar
no, it should be from germany, I bought it there ;)
lon - Responder Compartilhar
I'll change it for you ;)
Where can I purchase any mobile NFC chip and solder on to Galaxy S2 International version (I9100)?
Tai Li - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 28
Últimos 30 dias: 145
Ao todo: 567,061
