Pular para o conteúdo principal
Introdução
This is a Teardown of my old broken Samsung Galaxy Pocket (GT-S5300)
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua Samsung Galaxy Pocket (GT-S5300), use o nosso manual de serviço.
  1. Remove the battery cover Then remove the battery Then remove the battery
    • Remove the battery cover
    • Then remove the battery
  2. Remove all 4 screws Remove all 4 screws
    • Remove all 4 screws
  3. Slide a guitar pick between the sliver bezel and the rear of the phone Slide it all the way around until the rear is loosened from the logic board and screen
    • Slide a guitar pick between the sliver bezel and the rear of the phone
    • Slide it all the way around until the rear is loosened from the logic board and screen
  4. Kit de Reparo de Bateria do MacBook
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  5. Remove LCD connector Remove LCD connector
    • Remove LCD connector
  6. Remove logic board from screen by lifting  the logic board up and removing the digitizer connector
    • Remove logic board from screen by lifting the logic board up and removing the digitizer connector
  7. Remove the 5 screws to remove the shield Remove the 5 screws to remove the shield
    • Remove the 5 screws to remove the shield
  8. Remove what seems to be the antenna from the logic board Remove what seems to be the antenna from the logic board Remove what seems to be the antenna from the logic board
    • Remove what seems to be the antenna from the logic board
  9. Slide guitar pick between the digitizer and lcd Make sure not to get under the black adhesive on the back be the digitizer
    • Slide guitar pick between the digitizer and lcd
    • Make sure not to get under the black adhesive on the back be the digitizer
    • At the top of the digitizer there is a circuit be careful up there
  10. So that's my teardown for the Samsung galaxy pocket (GT-S5300)
    • So that's my teardown for the Samsung galaxy pocket (GT-S5300)
Ryan
Membro desde: 08-02-2014
360 reputação
Autoria de 1 guia
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 12
Últimos 30 dias: 59
Todo: 11,002
