Introdução
Samsung's line of phones-that-don't-fit-in-your-pocket is back! And in a Microsoftian move, they're going from Note5 straight to Note7. On the surface, it looks like an S7 Edge with a bigger screen and a fancy stylus, but we know better: no guts, no glory. It's teardown time!
Update: We added some sweet X-ray imagery, from our friends at Creative Electron.
Do you enjoy the odd teardown? We’ve got three (way cooler than two) ways to stay up to date with the latest repair news: find us on Twitter, join our inner circle on Facebook, and check out our Instagram!
O que você precisa
Vídeo de Apresentação
It's a mix of new and familiar as we peruse the Note7's specs:
Curved panel 5.7" Super AMOLED display with 2560 × 1440 resolution (518 ppi) and Gorilla Glass 5
Qualcomm Snapdragon 820 processor with 4 GB RAM + Adreno 530 GPU
12-megapixel, ƒ/1.7 rear camera with OIS, dual pixel autofocus, 4K video; 5-megapixel/1080p selfie camera
64 GB internal storage, with an additional 256 GB available via MicroSD expansion
Iris scanner, fingerprint scanner
S Pen stylus, USB-C, and headphone jack (phew)
IP68 dust and water resistance rating
As we boldly go where no tinkerer has gone before, we come across some
starports hiding out near the bottom edge. From left to right we observe: -
USB-C port
Microphone port
Speaker grille
That last one's not a port at all, it's the illustrious S Pen. Removing the S Pen is as smooth as slicing warm butter.
Our teardown hands are itching to get down to business, but we take a moment to test out the S Pen.
First impressions: this stylus stacks up pretty well against Microsoft's Surface Pen and Apple's Pencil.
The S Pen is smaller (and more stow-able) than either, but still has a scan rate of 360 Hz and senses 4,096 levels of pressure compared to the Pencil's 240 Hz and the Surface Pen's 1,024 levels of sensitivity.
Ferramenta utilizada nesse passo:iSclack$24.99
If opening stubbornly adhered Samsung devices was an Olympic sport, our teardown room would be filled with gold medals.
We take a minute to stretch while the iOpener works its magic, softening the adhesive under the rear glass.
Bang! The gun sounds. We fly off the starting blocks, iSclack and opening pick in hand. Pop! The rear glass dislodges from the chassis. Whoosh! The rest of the adhesive didn't stand a chance. Ka-pow! We're in.
Tinkerers love Phillips screws. Seeing these good ol' familiar screws draws our focus down to what they're securing: a sweet wireless charging coil.
We suspect the NFC antenna is also bundled into this wafer-thin assembly. NFC is no stranger to Galaxy Phones.
With that, we get our first full reveal of the Note7. [Cue oohs and aahs]
We come across an unusual battery cable design. At first glance, this is most definitely a slide. We're getting a little motion sick just looking at all of those winding curves.
Fortunately for us, a flick of a spudger is all it takes to pry the (off-kilter) battery connector cable off the motherboard.
With battery disconnected we delve deeper.
First victim: the single speaker, with built in antenna.
We could almost hear the battery laugh in our faces when we tried to pluck it out bare-handed—but our inner Hulk emerges as we muscle with all the might our spudger can muster.
This 3500 mAh, 13.48 Wh battery is significantly more powerful than the 10.45 Wh one found in the similarly sized iPhone 6s Plus, but it falls just a bit short of its smaller sibling, the Galaxy S7 Edge, which comes in at 13.86 Wh.
Curiously, the Note7's battery is fortified by walls carved from the rear case, providing extra structural integrity, and maybe even some water protection.
Dongguan ITM Electronics Company LTD, interesting that this name never appears in all the news stories about the exploding batteries.
That's because Samsung designs their new phones not to have replaceable batteries. It's starting to seem like a guaranteed way to make (most) people buy new devices every couple of years or so.
Out comes the motherboard, with three little cameras in tow.
Front and rear cameras are familiar fare on smartphones, so what's the third camera for?
For comparison we have the iris scanner (right) with the Note7's 5-megapixel, ƒ/1.7 selfie cam (left).
And for the X-ray comparison, here we have the two cameras still in the device.
Ferramenta utilizada nesse passo:Tweezers$4.99
With the motherboard deftly extracted, we take our tweezers to the hefty main camera and line him up for closer look.
It's déjà vu all over again as we pull out what appears to be the same Sony IMX260-based main camera that we uncovered in the S7 and S7 Edge.
... And the similarities go further, all the way down to:
the Winbond Q32FWXGIG serial flash memory
STMicroelectronics L2G2IS 2-Axis MEMS OIS Gyroscope
Renesas OIS Driver
We're down to the meat and potatoes of this teardown, and it seems like Samsung unified more than their product numbering—this chipset is nearly identical to that found in the S7 and S7 Edge.
Samsung K3RG2G20CMMGCJ 4 GB LPDDR4 SDRAM layered over a Qualcomm Snapdragon 820
Samsung KLUCG4J1CB-B0B1 64 GB Universal Flash Storage 2.0
Avago AFEM-9040 multiband multimode module
NXP PN67T NFC controller
Qorvo QM78064 high band RF fusion module, TQF6260 front-end module and QM63001A diversity receive module
Qualcomm WCD9335 audio codec and DSP Group DBMD4 audio/voice processor
Murata FAJ15 front-end module
More note-worthy chips hide on the backside:
Samsung 3420S7 G707A3 Wi-Fi module (most likely contains a Broadcom BCM4359 Wi-Fi SoC)
Wacom W9018 touch control IC
ZF10 110630 0625 (likely NXP Semiconductor I/O expander)
Qualcomm PM8996 and PM8004 PMICs
Qualcomm QFE3100 envelope tracker
IDT P9221S wireless power receiver (likely an iteration of IDT P9220) + Samsung S2MPB02 camera power management + Maxim Integrated MAX77838 power management IC
IC identification, pt. 2:
Infineon (previously Cypress Semiconductor) CY8CMBR3145 capacitive touch button controller
Samsung Image Processor (likely)
Samsung S2MM005X01 power management
Maxim Integrated MAX77854F power management
Maxim Integrated MAX98506 audio amplifier
Texas Instruments BQ25898S battery charger
ON Semiconductor FPF3688 load switch
IC identification, pt. 3:
RDA Microelectronics RDA6213 FM radio transceiver
Antenna switch module (likely)
NXP Semiconductor BGU8103 GPS/GLONASS/Galileo/BeiDou low noise amplifier
NXP Semiconductor BGS8H2 LTE low noise amplifier
NXP Semiconductor BGS8L2 LTE low noise amplifier
NXP Semiconductor BGS8M2 LTE low noise amplifier
Infineon BGS12SN6 SPDT RF switch
IC identification, pt. 4 (sensors):
Maxim Integrated MAX86902 heart rate sensor (likely)
STMicroelectronics LSM6DS3 3-axis accelerometer/gyroscope
Bosch Sensortec BMP280 pressure sensor
AKM Semiconductor AK09916 3-axis electronic compass
Seiko Instruments S-5712CCDL1-I4T1U hall effect sensor
Heading south, we hit the modular headphone jack—ready to let the music flow while keeping water out, with a nice sealing gasket.
The USB-C port is new to the Note line—and while reversibility is handy, change is hard. Samsung kindly includes a micro-USB-to-C adapter to keep your cables relevant.
Out goes the daughterboard array! Unlike the one found in the S7, this board used rigid PCB interconnects. This keeps the spidery cable from being flimsy. No one likes flimsy.
IC identification:
Qualcomm QFE2550 antenna tuner
Seiko Instruments S-5712CCDL1-I4T1U hall sensor
Semtech SX9320 proximity sensor (likely)
If you like tiny heat pipes, Note7 has you covered. This looks like the same "liquid cooling" copper heat dispersal apparatus we pulled from the vanilla S7 and S7 Edge.
Nearby, a note-able amount of glue secures this plastic cover over the S Pen chamber. It's probably there to help ingress-proof the stylus' slot.
Inside, a simple clip grabs the S Pen notches, and a gray rubber bumper protects the nib.
The volume buttons look pretty complicated, but that doesn't slow us down. Braced with years of experience plucking our unibrows, we dive in, a pair of tweezers in hand.
First out are the microswitches, followed by a reinforcement bracket full of rubber gaskets. Not quite the same, but similar to another waterproofing approach we've seen.
But...what's this? The button covers are oddly trapped within the outer case. We can't pop them out!
- Many components are modular and can be replaced independently.
- Improved cable routing means the charging port board can be removed without disassembling the display.
- The battery can be removed without first ousting the motherboard, but tough adhesive and a glued-on rear panel make replacement very difficult.
- Front and back glass make for double the crackability, and strong adhesive on the rear glass makes it very difficult to gain entry into the device.
- Because of the curved screen, replacing the front glass without destroying the display is probably impossible.
Considerações finais
Índice de reparabilidade
(10 é o mais fácil de reparar)
48 comentários
Is it possible to keep the water resistance after opening the phone for something simple like battery replacement
The phones are a utmost rarity, but it is possible. You would have to use glue to reset the back cover and maintain the water-tightness. E7000 does the trick though!
I will take my chances with this device to replace my note 4
I just did that and I dont like it.... The screen is not as wide because of the curve
Can you verify whether the phone will support 4x4 MIMO for LTE?
Some versions ll support 4*4 MIMO with qualcomm 820 chipset.
Lee -
I see no home button :/
First picture in step 2 has it
The ones that support 4x4 mimo are the qualcomm 820 ones not the exynos powered note 7s
4/10 repairability for the Note 7, and 7/10 repairability for the 6S? Come on Samsung, give that corruption money to iFixit so they can give you good scores arbitrarily...
do you even see an open iphone ? or you are just a troll that wants to say anything...I changed my iPhone screen without any knowledge about phone repairing...
Hadi -
dude iphone 6s doesn't have adhesive to open the phone, so yeah they have higher score in that.
beside see iphone7 which has a lot of adhesive for protect from water and dust
I wouldn't call going from Note 5 to Note 7 the same as what Microsoft had to do. Do you realize how many websites and web based software apps rely on OS detection? It would make all the systems looking for windows9x break, badly. Samsung just want their version to start matching to help prevent confusion with the consumers.
Can this phone make a call from Ireland to Northern California? What about from Portland, OR to Portland, ME??
Yes and yes, if you have international calling.
Anyone k now if taking off the back cover messes up the waterproofing in any way? On my Note 5 I took the back cover off (very easy) and was able to repaint it a nice black with no logos and also put in small pieces of tin paper so it stuck on my magnetic car holder. But I'm hesitant to remove the Note 7 back. The process looks as easy as the Note 5, but I'm afraid of ruining the waterproof design.
I think you're right, good catch! Thank you!
Unfortunately they've all been recalled because of exploding batteries.....
Well the note 7 battery explodes
Because ifixit is a website of USA...
因为iFixit是美国网站
太可惜了 这么好的设计!
So I wanna buy a Galaxy Note 8
所以我想买Note8
Did anybody try using external lipo battery with this device (or even a few 18650 cells in 4p1s configuration) :-)?
(instead of internal combutible one), or just slot in 1.5 AH 20C cell from the RC lipo pack instead of 3.5AH combustible one?
If coupled with good BMS circuit it would make this device safe instantly :-).
Perhaps you can add a battery from a different Samsung phone. Or only fast-charge from the wall and place the charger on a timer, 15m on and 15m off to prevent battery heating.
And something Samsung can do with the people that refuse to turn over their phone is to ask them politely if they want battery logging data stored on the phone to help find the cause of the problem, turn it into a research project (using a new app I guess). This would prevent their next phone doing the same thing. The app could send a SOS (known from the phone’s rising temperature) and the collected data as the phone is combusting if it is WIFI/4G connected at the time. If the problem is found, the recall could be halted if it can be solved with a software patch (even if it is a battery problem – although liion tech is susceptable to insulation peircing from crystal growths in the battery and that is not avoidable).
翻译这些文章实在是个麻烦事,所以目前只有英文版和法语版,而且法语版内容还很少。。。
It's so challenging to translate these articles, so only English and French versions of iFixit are available, and there's much less contents in French version.
تشكرات ^_^ كثيرات
we selling of as follow :
Samsung Galaxy Note7 – Replacement main camera and real camera module set,
- Condition : just Pulled from Original Note7 through Samsung.
- Q’ty : 300,000sets and more 1,000,000sets
-Price : low price ( contact us now by e mail - lcdpanelseller@gmail.com
we selling of other parts for Note7 pulled parts.
im looking for samsung note 7 lcd replacement? anyone have? just pm me in my accnt jaypee.aparta@gmail.com or reply bellow! thanks
