Ir para o conteúdo principal
O que você precisa
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua Samsung GT-E2120, use o nosso manual de serviço.
  1. Samsung GT-E2120 Teardown, Samsung GT-E2120 Teardown: passo 1, imagem 1 %32
    • Before you begin it's always good to ground yourself to eliminate the risk for shock.
  2. Samsung GT-E2120 Teardown: passo 2, imagem 1 %32 Samsung GT-E2120 Teardown: passo 2, imagem 2 %32
    • Using your thumb, press down on the back of the device in a downward motion to open the back cover.
    • Remove the battery along with the sim card and Micro-SD card.
    • This phone can take up to a 2GB Micro-SD card and is great for storing music. It even has a FM radio!
  3. Samsung GT-E2120 Teardown: passo 3, imagem 1 %32 Samsung GT-E2120 Teardown: passo 3, imagem 2 %32
    • Next, using a Philips screwdriver, remove the five screws from the back of the device.
  4. Samsung GT-E2120 Teardown: passo 4, imagem 1 %32 Samsung GT-E2120 Teardown: passo 4, imagem 2 %32 Samsung GT-E2120 Teardown: passo 4, imagem 3 %32
    • For this step a matal spudger is used to release the clips along the bottom, top, and sides of the phone.
    • These clips can be found at the points marked in red.
    • Working from the top down, gently prying at the case the clips are easily dislodged.
  5. Samsung GT-E2120 Teardown: passo 5, imagem 1 %32 Samsung GT-E2120 Teardown: passo 5, imagem 2 %32
    • When the bottom of the phone is reached it is a bit harder to pull the bottom clips off.
    • This can be made a tad easier by using the pointed end of the spudger to get in and under the case.
    • Once the case is lifted up slightly, you can get enough purchase under the clip and lift it off.
    • Be careful so you dont damage the motherboard!
  6. Samsung GT-E2120 Teardown: passo 6, imagem 1 %32
    • This images shows the two halves separated.
    • The camera located in the blue square is a VGA 640X480 resolution color camera.
  7. Samsung GT-E2120 Teardown: passo 7, imagem 1 %32 Samsung GT-E2120 Teardown: passo 7, imagem 2 %32
    • The microphone is carefully lifted from its bracket, and the motherboard is carefully removed.
  8. Samsung GT-E2120 Teardown: passo 8, imagem 1 %32
    • Then the keyboard is simply pushed out.
    • The Phone includes a 65K CSTN color screen with a 128X128 resolution.
Michael C
Membro desde: 01/09/11
410 Reputação
Autoria de 1 guia
Equipe
OPEN Membro de OPEN
Community
85 Membros
Autoria de 28 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 18
Últimos 30 dias: 36
Ao todo: 14,345
