Ir para o conteúdo principal
O que você precisa
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua Samsung Evergreen SGH-A667, use o nosso manual de serviço.
  1. Samsung Evergreen SGH-A667 Teardown, Samsung Evergreen SGH-A667 Teardown: passo 1, imagem 1 %32 Samsung Evergreen SGH-A667 Teardown, Samsung Evergreen SGH-A667 Teardown: passo 1, imagem 2 %32
  2. Samsung Evergreen SGH-A667 Teardown: passo 2, imagem 1 %32
    • Begin by prying off the rear battery-access panel.
  3. Samsung Evergreen SGH-A667 Teardown: passo 3, imagem 1 %32 Samsung Evergreen SGH-A667 Teardown: passo 3, imagem 2 %32
    • Remove battery pack and SIM card.
    • Remove the seven screws marked in red.
  4. Samsung Evergreen SGH-A667 Teardown: passo 4, imagem 1 %32 Samsung Evergreen SGH-A667 Teardown: passo 4, imagem 2 %32
    • Pry the case away from the body of the phone. Be gentle around the volume control, micro USB, and micro SD ports.
  5. Samsung Evergreen SGH-A667 Teardown: passo 5, imagem 1 %32 Samsung Evergreen SGH-A667 Teardown: passo 5, imagem 2 %32
    • Camera
    • Keyboard ribbon connector
    • Microphone
    • Remove the two screws marked in red to free the EMI shielding.
  6. Samsung Evergreen SGH-A667 Teardown: passo 6, imagem 1 %32
    • The keyboard ribbon strings each of the pieces together, but the keypad flops right out on its own.
  7. Samsung Evergreen SGH-A667 Teardown: passo 7, imagem 1 %32 Samsung Evergreen SGH-A667 Teardown: passo 7, imagem 2 %32
    • Remove the six screws marked in red; they hold the keyboard to the sliding mechanism.
  8. Samsung Evergreen SGH-A667 Teardown: passo 8, imagem 1 %32 Samsung Evergreen SGH-A667 Teardown: passo 8, imagem 2 %32 Samsung Evergreen SGH-A667 Teardown: passo 8, imagem 3 %32
    • Huzzah the sliding carriage is free—what's that? The funk of forty thousand years? This part of the phone never sees the light of day!
    • Remove the six screws circled in red.
    • Sometimes this screw is hidden by the ribbon cable!
  9. Samsung Evergreen SGH-A667 Teardown: passo 9, imagem 1 %32 Samsung Evergreen SGH-A667 Teardown: passo 9, imagem 2 %32 Samsung Evergreen SGH-A667 Teardown: passo 9, imagem 3 %32
    • More plastic clips means a little more finagling to pry the front case off.
    • The work pays off with a snappy line-up.
  10. Samsung Evergreen SGH-A667 Teardown: passo 10, imagem 1 %32 Samsung Evergreen SGH-A667 Teardown: passo 10, imagem 2 %32
    • Gently flex the faceplate to loosen the adhesive's hold on the screen.
    • After loosening all edges, begin to peel the LCD from the plastic. When in doubt, stop, look, and listen; just like crossing the street.
  11. Samsung Evergreen SGH-A667 Teardown: passo 11, imagem 1 %32
    • The sum of its parts
    • Use these steps in reverse to reassemble—a method tried and true!
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 15
Duração total: 897
