Ir para o conteúdo principal
O que você precisa
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua Rubik's Cube, use o nosso manual de serviço.
  1. Rubik's Cube Teardown, Rubik's Cube Teardown: passo 1, imagem 1 %32 Rubik's Cube Teardown, Rubik's Cube Teardown: passo 1, imagem 2 %32 Rubik's Cube Teardown, Rubik's Cube Teardown: passo 1, imagem 3 %32
    • Turn the top row so that each corner is roughly halfway between the sides
    • Push the pieces up until they pop out of the cube, then, slide the rest out
    • Repeat this process until you clear the level
  2. Rubik's Cube Teardown: passo 2, imagem 1 %32 Rubik's Cube Teardown: passo 2, imagem 2 %32
    • You should be able to just directly pull out the rest of the blocks, like so
    • And there you have it!
    • You'll have the center piece, with the six centers of the six sides, the turning mechanism
  3. Rubik's Cube Teardown: passo 3, imagem 1 %32 Rubik's Cube Teardown: passo 3, imagem 2 %32
    • To reassemble, snap all the pieces back into place, and try not to rotate the faces.
    • It helps to start with the middle pieces first
    • Don't be afraid to use force!
    • Once you have the middle pieces in it's pretty simple to just push in the corner pieces
    • Again- don't be afraid to use force!
rab777hp
Membro desde: 11/17/09
20.333 Reputação
Autoria de 3 guias
Equipe
OPEN Membro de OPEN
Community
Membros da 82
Autoria de 25 guias
6 comentários
I hated this thing. I disassembled mine with a .22 hollow point at 100 yards. Yes, It felt great!
mpias - Responder
lol don’t blame you, can’t stand the thing
Luke -
that method just broke my rubiks my cube.. thanks anyway
hamzamagdy888 - Responder
my middle peices came out cant fix it
jax - Responder
can someone tell me how to fix it
jax - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 11
Últimos 30 dias: 29
Duração total: 24,546
