Ir para o conteúdo principal
O que você precisa
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua Rowenta AC6221, use o nosso manual de serviço.
  1. Rowenta AC6221 Teardown, Rowenta AC6221 Teardown: passo 1, imagem 1 %32 Rowenta AC6221 Teardown, Rowenta AC6221 Teardown: passo 1, imagem 2 %32 Rowenta AC6221 Teardown, Rowenta AC6221 Teardown: passo 1, imagem 3 %32
    • The 4.8 Rowenta vacuum can be used for a variety of purposes.
    • It is charged through its pedestal. The power of the pedestal is:
    • Input: 230V - 50 Hz - 7W (AC)
    • Output: 7.5V - 300 mA (DC)
  2. Rowenta AC6221 Teardown: passo 2, imagem 1 %32 Rowenta AC6221 Teardown: passo 2, imagem 2 %32 Rowenta AC6221 Teardown: passo 2, imagem 3 %32
    • This vacuum has several parts:
    • The tip
    • The reservoir which holds the dust and debris
    • The engine (4.8V)
    • The pedestal
    • The power supply
    • From top to bottom, the reservoir contains 3 parts: the housing, container, and filter.
  3. Rowenta AC6221 Teardown: passo 3, imagem 1 %32 Rowenta AC6221 Teardown: passo 3, imagem 2 %32 Rowenta AC6221 Teardown: passo 3, imagem 3 %32
    • Remove the two outer Philips #00 screws from the bottom of the engine.
    • The back of the circuit board will now be visible.
  4. Rowenta AC6221 Teardown: passo 4, imagem 1 %32 Rowenta AC6221 Teardown: passo 4, imagem 2 %32 Rowenta AC6221 Teardown: passo 4, imagem 3 %32
    • Remove the two inner screws.
    • Insert a flat screwdriver between the cover and the base of the engine and remove the cover.
    • The wires of the vacuum are now visible.
  5. Rowenta AC6221 Teardown: passo 6, imagem 1 %32 Rowenta AC6221 Teardown: passo 6, imagem 2 %32
    • The wires connect the charger light, switch,engine, and power wires.
    • The green box labels the engine.
    • The orange box labels one of the four batteries (4*1.2V)
  6. Rowenta AC6221 Teardown: passo 7, imagem 1 %32 Rowenta AC6221 Teardown: passo 7, imagem 2 %32
    • The top of the circuit board contains components including capacitors, resistors, wires, and a chip.
    • The bottom side shows the tracks that connect the components.
  7. Rowenta AC6221 Teardown: passo 8, imagem 1 %32 Rowenta AC6221 Teardown: passo 8, imagem 2 %32
    • Remove the screw securing the handle with a screwdriver.
    • Open the handle to see the inside using the flat screwdriver.
    • Warning: The handle is difficult to open
    • Warning: In this procedure, the handle was not opened to keep the vacuum intact.
  8. Rowenta AC6221 Teardown: passo 9, imagem 1 %32
    • This is the pedestal that will be torn down.
  9. Rowenta AC6221 Teardown: passo 10, imagem 1 %32 Rowenta AC6221 Teardown: passo 10, imagem 2 %32 Rowenta AC6221 Teardown: passo 10, imagem 3 %32
    • At the bottom of the pedestal, remove the 4 rubber pieces.
    • Note: This step provides access to 4 Philips screws.
    • Remove screws using a screwdriver.
  10. Rowenta AC6221 Teardown: passo 11, imagem 1 %32
    • Lift the plastic piece carefully from the bottom of the pedestal.
  11. Rowenta AC6221 Teardown: passo 12, imagem 1 %32
    • Inside the pedestal, the power cable separates into 2 wires. Each wire is connected to a conductive piece.
    • This completes the vacum cleaner teardown
Bob
Membro desde: 04/17/10
760 Reputação
Autoria de 3 guias
Um comentário
This could use some discussion of how to replace the rechargeable batteries used in portable vacuum cleaners.
Wayne Seltzer - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 16
Duração total: 7,214
