Ir para o conteúdo principal
O que você precisa
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua Tweezers, use o nosso manual de serviço.
  1. Reversed tweezers Teardown, Reversed tweezers Teardown: passo 1, imagem 1 %32 Reversed tweezers Teardown, Reversed tweezers Teardown: passo 1, imagem 2 %32 Reversed tweezers Teardown, Reversed tweezers Teardown: passo 1, imagem 3 %32
    • This my friends, is the first ever iFixit-made-tool teardown on iFixit
    • Stainless steel body and nylon tips, with the iFixit logo printed on it...
    • Reversed so you can hold tiny Lego hats even when your hands are busy...
  2. Reversed tweezers Teardown: passo 2, imagem 1 %32 Reversed tweezers Teardown: passo 2, imagem 2 %32 Reversed tweezers Teardown: passo 2, imagem 3 %32
    • Time to tear it down!
    • Its not often that regular Philips screws are used on modern devices!
    • So far we've been able to take off a lot of the tool's construction using Only a PH0 screwdriver!
    • Have dreams come true?
    • We Remove the Last parts anddddd...
  3. Reversed tweezers Teardown, Final Thoughts: passo 3, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Nylon Tipped Tweezers
    $2.99
    Comprar
    What is the pitch between the screw holes?
    Colton - Responder
    Also, do you know what the thickness of the tips are and the length of the screws?
    Colton - Responder
Aiden
Membro desde: 09/19/15
17.429 Reputação
Autoria de 21 guias
8 comentários
Where can you find the replacement parts?
echow2001 - Responder
Repairability: 11 out of 10.
Jake Rose - Responder
lol i actually needed this to fix mine
Luke - Responder
Very glad to know replacement tips are sold! I had no idea these were nylon until I melted the ends. Whoops!
The Purple Ender Eye - Responder
If you have the order number of the original or a photo of the kit it came with, theyll replace it for free if you use their email support.
Tito_deTrapio94 -
So I have to purchase the Nylon Tipped Tweezers to get a set of Nylon Tips to replace my Reverse Tweezers Nylon Tips? Can't jus buy the tips?
Randy
Clarence Hayes - Responder
You can definitely get the tips only. And they are covered by the lifetime warranty. Just contact their email support. they sent me 2 replacement packs for free.
Tito_deTrapio94 -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 41
Duração total: 3,502
