Ir para o conteúdo principal
O que você precisa
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua BlackBerry 7290, use o nosso manual de serviço.
  1. RIM Blackberry 7290 Teardown, Battery: passo 1, imagem 1 %32 RIM Blackberry 7290 Teardown, Battery: passo 1, imagem 2 %32 RIM Blackberry 7290 Teardown, Battery: passo 1, imagem 3 %32
    • Apply pressure to the lock button on the back of the device.
    • Slide the battery cover down towards the bottom of the device, revealing the battery compartment.
  2. RIM Blackberry 7290 Teardown: passo 2, imagem 1 %32 RIM Blackberry 7290 Teardown: passo 2, imagem 2 %32 RIM Blackberry 7290 Teardown: passo 2, imagem 3 %32
    • Locate groove along the right side of the battery compartment.
    • Remove battery by prying between the battery and the groove.
  3. RIM Blackberry 7290 Teardown, SIM Card: passo 3, imagem 1 %32
    • Slide the SIM card holder to the left to unlock the SIM card.
  4. RIM Blackberry 7290 Teardown: passo 4, imagem 1 %32 RIM Blackberry 7290 Teardown: passo 4, imagem 2 %32
    • Lift the SIM card holder up.
    • Gently remove the SIM card from the SIM card holder by sliding the card along the railing.
  5. RIM Blackberry 7290 Teardown, Side Button: passo 5, imagem 1 %32
    • Locate the four screws along the perimeter of the back casing.
    • Remove the four top screws using a T-6 torx screwdriver.
    • The top four screws are .413 inches.
  6. RIM Blackberry 7290 Teardown: passo 6, imagem 1 %32 RIM Blackberry 7290 Teardown: passo 6, imagem 2 %32
    • Locate two screws within the lower edge of the inner compartment.
    • Remove the two bottom screws using a T-6 torx screwdriver.
    • The bottom two screws are .2 inches in length.
    • The second picture displays the device after the six screws have been removed.
  7. RIM Blackberry 7290 Teardown: passo 7, imagem 1 %32
    • Use the plastic opening tool to apply pressure on the two clips that are located at the bottom of the phone.
  8. RIM Blackberry 7290 Teardown: passo 8, imagem 1 %32 RIM Blackberry 7290 Teardown: passo 8, imagem 2 %32 RIM Blackberry 7290 Teardown: passo 8, imagem 3 %32
    • Remove the back casing from the phone by lifting the unhooked portion, then slide the casing towards the top of the device.
    • Make sure all clips holding the case together are unhooked, so no damage is caused to the case.
  9. RIM Blackberry 7290 Teardown: passo 9, imagem 1 %32 RIM Blackberry 7290 Teardown: passo 9, imagem 2 %32
    • Locate on the backside of the phone, a screw towards the top of the device.
    • Using a T-6 screwdriver, remove the screw.
    • After the screw has been removed, carefully lift the side button brace to reveal the side button.
  10. RIM Blackberry 7290 Teardown, Keypad: passo 10, imagem 1 %32
    • To remove the phone's internals, start by loosening one side by pulling gently.
  11. RIM Blackberry 7290 Teardown: passo 11, imagem 1 %32
    • With one side loosened, simply lift the phone internals to separate from the front casing.
  12. RIM Blackberry 7290 Teardown: passo 12, imagem 1 %32
    • Turn the internals over to reveal the LCD display.
  13. RIM Blackberry 7290 Teardown: passo 13, imagem 1 %32 RIM Blackberry 7290 Teardown: passo 13, imagem 2 %32
    • Peel off the rubber keypad buttons from the face plate.
  14. RIM Blackberry 7290 Teardown, LCD: passo 14, imagem 1 %32
    • Locate a hook on the right side of the internals below the volume wheel.
    • Use a plastic opening tool to gently pry the hook, separating the LCD display from the logic board mounting plate.
  15. RIM Blackberry 7290 Teardown: passo 15, imagem 1 %32 RIM Blackberry 7290 Teardown: passo 15, imagem 2 %32
    • With the clip unhooked, gently separate the display from the phone internals by pulling.
  16. RIM Blackberry 7290 Teardown, Logic Board: passo 16, imagem 1 %32
    • On the front side of the internals, locate the the three screws that are highlighted in red.
    • Carefully remove screws from the internals, using a T6 torx screwdriver
    • The screw is .2 inches in length.
  17. RIM Blackberry 7290 Teardown: passo 17, imagem 1 %32 RIM Blackberry 7290 Teardown: passo 17, imagem 2 %32
    • Separate the logic board mounting plate from the logic board by lifting with minimal force.
  18. RIM Blackberry 7290 Teardown, RIM Blackberry 7290 Teardown: passo 18, imagem 1 %32 RIM Blackberry 7290 Teardown, RIM Blackberry 7290 Teardown: passo 18, imagem 2 %32
    • These are all the components of the phone.
kenny34
Membro desde: 10/28/09
75 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 19-6, Maness Fall 2009 Membro de Cal Poly, Team 19-6, Maness Fall 2009
CPSU-MANESS-F09S19G6
Membros da 5
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 11
Duração total: 6,431
