Introdução
This is a teardown showing how a Pwnagotchi works.For this guide, I am doing a teardown of my Pwnagotchi build
Every Pwnagotchi is different in some way, except most will have an E-Ink display such as a Waveshare and the Raspberry Pi Zero. Some Pwnagotchi units can run on different Raspberry Pi units or computers that work like the Raspberry pi!
O que você precisa
The green LED is the Rasperry Pi Zero's data indicator. This will flash as the SD card is being read/written to
The Blue LED is from the embedded battery in the Pwnagtochi casing. This LED only turns on when the battery is being used
If possible, remove the outer casing of your Pwnagotchi. For this guide, our case has a removeable top and bottom so we can access the screen and battery
With the Top cover removed, we can see that the Pwnagotchi has a Waveshare E-Ink Display.
This area is covered by the 3D printed case to protect the display ribbon and electronics
The GIPO Ports all go inside the raspberry Pi Zero, you will not need the white, 8-pin header (It can be removed if you want to have a slimmer pwnagotchi)
There are different connectors for this build, to better understand them, this is what they are used for:
Connectors/Ports on the raspberry pi zero
Mini HDMI Port
Power Port (Rated around 5-5.25V)
Ports/Connectors on the battery
Battery Power port
Battery Power Switch
