Ir para o conteúdo principal
O que você precisa
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua Power Mac G4 MDD, use o nosso manual de serviço.
  1. Powermac G4 MDD (Mirrored Drive Doors) Teardown, Case: passo 1, imagem 1 %32 Powermac G4 MDD (Mirrored Drive Doors) Teardown, Case: passo 1, imagem 2 %32
    • The Power Mac G4 MDD: the last, and the fastest G4-based Mac. This computer boasted up to a Dual 1.42GHz PowerPC G4 CPU (though I have a single 1.25GHz).
    • Two USB 1.1 Ports
    • Assorted Audio
    • Video (ADC & DVI)
    • Networking (RJ-45 Ethernet/56k Modem)
    • Some later model MDD's (such as the dual 1.42GHz) Have a FireWire 800 Port Here:
  2. Powermac G4 MDD (Mirrored Drive Doors) Teardown: passo 2, imagem 1 %32 Powermac G4 MDD (Mirrored Drive Doors) Teardown: passo 2, imagem 2 %32 Powermac G4 MDD (Mirrored Drive Doors) Teardown: passo 2, imagem 3 %32
    • Unplug the computer.
    • Unplug the power supply and all external connections from the computer.
    • Pull on the side lever and lower the side of the case.
  3. Powermac G4 MDD (Mirrored Drive Doors) Teardown, RAM: passo 3, imagem 1 %32 Powermac G4 MDD (Mirrored Drive Doors) Teardown, RAM: passo 3, imagem 2 %32 Powermac G4 MDD (Mirrored Drive Doors) Teardown, RAM: passo 3, imagem 3 %32
    • The ram is between the graphics card, and the CPU, and removal is simple. Push the tabs down on both sides, this will free the ram, then lift it out.
    • The MDD uses a maximum of 2GB PC2700 DDR RAM (512MB X4) and has 4 slots.
  4. Powermac G4 MDD (Mirrored Drive Doors) Teardown, AirPort Card: passo 4, imagem 1 %32 Powermac G4 MDD (Mirrored Drive Doors) Teardown, AirPort Card: passo 4, imagem 2 %32 Powermac G4 MDD (Mirrored Drive Doors) Teardown, AirPort Card: passo 4, imagem 3 %32
    • The AirPort card is located next to the graphics card.
    • If your computer has a FireWire 800 port between the FireWire 400 Ports and the Ethernet Ports then your computer uses an AirPort Extreme 802.11g Card (See Related Parts). If your computer has no firewire 800 port, then your computer uses an 802.11b AirPort PCMCIA Card (Also See Related Parts). Removal of both cards is pretty much the same.
    • First disconnect the antenna from the card, it may be helpful to use a spudger or flathead screwdriver.
    • Now, grasp the plastic tab on the back of the card and pull it out of the computer.
  5. Powermac G4 MDD (Mirrored Drive Doors) Teardown: passo 5, imagem 1 %32
    • The Airport 802.11b PCMCIA Card.
  6. Powermac G4 MDD (Mirrored Drive Doors) Teardown, Hard Drives: passo 6, imagem 1 %32
    • The hard drive cages are located here.
  7. Powermac G4 MDD (Mirrored Drive Doors) Teardown: passo 7, imagem 1 %32 Powermac G4 MDD (Mirrored Drive Doors) Teardown: passo 7, imagem 2 %32 Powermac G4 MDD (Mirrored Drive Doors) Teardown: passo 7, imagem 3 %32
    • Cage 1
    • Start by removing this screw.
    • Remove the ATA-66/ IDE ribbon cable from the motherboard.
  8. Powermac G4 MDD (Mirrored Drive Doors) Teardown: passo 8, imagem 1 %32 Powermac G4 MDD (Mirrored Drive Doors) Teardown: passo 8, imagem 2 %32
    • Now, remove the power connection from the drives.
  9. Powermac G4 MDD (Mirrored Drive Doors) Teardown: passo 9, imagem 1 %32 Powermac G4 MDD (Mirrored Drive Doors) Teardown: passo 9, imagem 2 %32 Powermac G4 MDD (Mirrored Drive Doors) Teardown: passo 9, imagem 3 %32
    • Push this tab down, and pull the cage toward you.
    • Now, you can set cage 1 aside.
  10. Powermac G4 MDD (Mirrored Drive Doors) Teardown: passo 10, imagem 1 %32 Powermac G4 MDD (Mirrored Drive Doors) Teardown: passo 10, imagem 2 %32
    • Cage 2:
    • Remove this Phillips screw:
    • Disconnect this IDE ribbon cable from the logic board.
  11. Powermac G4 MDD (Mirrored Drive Doors) Teardown: passo 11, imagem 1 %32 Powermac G4 MDD (Mirrored Drive Doors) Teardown: passo 11, imagem 2 %32
    • It's likely that there is a cable clip holding the ribbon cable to the case.
    • To remove it, push the end, and it should pop up.
  12. Powermac G4 MDD (Mirrored Drive Doors) Teardown: passo 12, imagem 1 %32 Powermac G4 MDD (Mirrored Drive Doors) Teardown: passo 12, imagem 2 %32 Powermac G4 MDD (Mirrored Drive Doors) Teardown: passo 12, imagem 3 %32
    • With the ribbon cable clip free, pull this tab towards you, slide the cage up until it hits the platform under the power supply, and pull it away.
    • Now, set the cage on top of the CPU, and remove the power connectors.
  13. Powermac G4 MDD (Mirrored Drive Doors) Teardown: passo 13, imagem 1 %32 Powermac G4 MDD (Mirrored Drive Doors) Teardown: passo 13, imagem 2 %32
    • Once the cables are free, set the drive cage aside.
    • To remove the hard drives from the cages, remove the four screws on the sides of the cage that are connected to the drives, then slide the drives out.
    • The two cages are cross compatible and can be put in either location.
    • The MDD does not have a 128GB drive limit like older Macs. My MDD has 3 drives (a 400GB Hitatchi Deskstar, 40GB Seagate Barracuda 7200.7, and a 30GB Quantum Fireball LCT).
    • Note the ID jumpers on the two drive set. One is set to Master, the other to slave. A single drive can be set to Cable Select.
  14. Powermac G4 MDD (Mirrored Drive Doors) Teardown, Optical Drive Cage: passo 14, imagem 1 %32 Powermac G4 MDD (Mirrored Drive Doors) Teardown, Optical Drive Cage: passo 14, imagem 2 %32
    • Start removing the optical drive cage by removing its back cover.
  15. Powermac G4 MDD (Mirrored Drive Doors) Teardown: passo 15, imagem 1 %32 Powermac G4 MDD (Mirrored Drive Doors) Teardown: passo 15, imagem 2 %32 Powermac G4 MDD (Mirrored Drive Doors) Teardown: passo 15, imagem 3 %32
    • Now, remove the IDE and power cables from the drives.
  16. Powermac G4 MDD (Mirrored Drive Doors) Teardown: passo 16, imagem 1 %32 Powermac G4 MDD (Mirrored Drive Doors) Teardown: passo 16, imagem 2 %32 Powermac G4 MDD (Mirrored Drive Doors) Teardown: passo 16, imagem 3 %32
    • Remove these two Phillips screws:
    • Pull the cage away from the front until it is free.
    • Slide the cage towards you, and out of the Mac.
  17. Powermac G4 MDD (Mirrored Drive Doors) Teardown: passo 17, imagem 1 %32 Powermac G4 MDD (Mirrored Drive Doors) Teardown: passo 17, imagem 2 %32
    • To remove the drive(s) from the cage, remove the two screws on each side of the drive(s), then pull the drive out of the cage.
    • My MDD has a 3rd party 22X SuperDrive, for burning DVD's in Leopard (Thank You Generic Drive Support!)
  18. Powermac G4 MDD (Mirrored Drive Doors) Teardown, Graphics Card: passo 18, imagem 1 %32
    • The Power Mac G4 MDD uses a Mac-Compatible AGP Graphics card with ADC, And DVI or VGA.
    • My mac has a NVIDIA GeForce4 Titanium with 128MB of video ram, this was an excessively large card, for some reason.
    • Start by removing this Phillips screw.
  19. Powermac G4 MDD (Mirrored Drive Doors) Teardown: passo 19, imagem 1 %32 Powermac G4 MDD (Mirrored Drive Doors) Teardown: passo 19, imagem 2 %32 Powermac G4 MDD (Mirrored Drive Doors) Teardown: passo 19, imagem 3 %32
    • Using a flathead screwdriver, spudger, or your finger pull this tab towards you, and lift the card out.
    • The "excessively large" NVIDIA GeForce4 Titanium 128MB. This was one of the most powerful cards on the market when this computer was released, now, there are flashed cards such as the Radeon 9700 Mac, but this is the most powerful AGP ADC supporting card, great for gaming, Photoshop, and other 3D intensive applications.
  20. Powermac G4 MDD (Mirrored Drive Doors) Teardown: passo 20, imagem 1 %32 Powermac G4 MDD (Mirrored Drive Doors) Teardown: passo 20, imagem 2 %32
    • The DVI And ADC Ports.
  21. Powermac G4 MDD (Mirrored Drive Doors) Teardown, PCI Cards: passo 21, imagem 1 %32 Powermac G4 MDD (Mirrored Drive Doors) Teardown, PCI Cards: passo 21, imagem 2 %32
    • The Power Mac G4 MDD Supports four PCI Cards, allowing for SCSI, sound, wireless networking (only AirPort compatible clones) USB, FireWire, etc. The PCI slots do not, however support PCI graphics.
    • Remove the screws for any occupied PCI bays.
  22. Powermac G4 MDD (Mirrored Drive Doors) Teardown: passo 22, imagem 1 %32
    • Once the screws are removed, pull each card straight up and out of the computer one at a time.
    • The Cards:
    • Adaptec SCSI 50-Pin
    • Adaptec SCSI 68-Pin
    • USB/FireWire Expander
    • M-Audio HD Sound Card
    • NVIDIA GeForce4 Titanium (Mac Edition) DVI & ADC
  23. Powermac G4 MDD (Mirrored Drive Doors) Teardown, System Fan: passo 23, imagem 1 %32 Powermac G4 MDD (Mirrored Drive Doors) Teardown, System Fan: passo 23, imagem 2 %32
    • You may find removing the system fan is unnecessary to remove the power supply cable from behind it, but if you're unfamiliar with how the power supply cable is situated behind the fan, this step is useful in seeing this.
    • Disconnect the optical drive IDE/ATA-33 cable from the logic board.
    • Disconnect the system fan 2-wire power cable connector from the logic board.
  24. Powermac G4 MDD (Mirrored Drive Doors) Teardown: passo 24, imagem 1 %32 Powermac G4 MDD (Mirrored Drive Doors) Teardown: passo 24, imagem 2 %32 Powermac G4 MDD (Mirrored Drive Doors) Teardown: passo 24, imagem 3 %32
    • Grab the system fan by its sides and pull it up and out. The system fan is very large and loud, compared to standard sized fans.
  25. Powermac G4 MDD (Mirrored Drive Doors) Teardown, Power Supply: passo 25, imagem 1 %32 Powermac G4 MDD (Mirrored Drive Doors) Teardown, Power Supply: passo 25, imagem 2 %32
    • To remove the power supply connector from the motherboard, push the top end of this clip towards the power supply connector, and pull the connector up and off the motherboard. If the connector seems to be stuck, rock it back and forth a tiny bit to loosen up the connection, then pull up again.
  26. Powermac G4 MDD (Mirrored Drive Doors) Teardown: passo 26, imagem 1 %32 Powermac G4 MDD (Mirrored Drive Doors) Teardown: passo 26, imagem 2 %32 Powermac G4 MDD (Mirrored Drive Doors) Teardown: passo 26, imagem 3 %32
    • Push on these two clips here to release the power cable.
    • Thread the power cable out of the small hole it comes through, at the far side of the Mac.
  27. Powermac G4 MDD (Mirrored Drive Doors) Teardown: passo 27, imagem 1 %32 Powermac G4 MDD (Mirrored Drive Doors) Teardown: passo 27, imagem 2 %32
    • There may be a small 2.5mm hex (not Torx) screw here on the back of the case, it must be removed if present:
  28. Powermac G4 MDD (Mirrored Drive Doors) Teardown: passo 28, imagem 1 %32 Powermac G4 MDD (Mirrored Drive Doors) Teardown: passo 28, imagem 2 %32
    • Slide the power supply towards the front of the case, and pull it out. It is a little heavy, so don't drop it on the logic board. Disconnect any drive power connectors that you may not have already connected.
  29. Powermac G4 MDD (Mirrored Drive Doors) Teardown: passo 29, imagem 1 %32 Powermac G4 MDD (Mirrored Drive Doors) Teardown: passo 29, imagem 2 %32
    • The power supply has a 24-pin connector with non-standard voltages, so dropping in a 24-pin ATX power supply without modification isn't a great idea.
    • The power supply connector has a 25V lead to drive Apple ADC displays, so though it is possible to modify an ATX power supply, it won't be able to drive ADC displays, just VGA, or DVI, though the computer will work fine (I've actually tried this).
    • It also has three 12V/5V rails to drive all six drives (four hard drives, two optical drives) simultaneously. This is the only Macintosh computer other than the Mac Pro to support six drives.
  30. Powermac G4 MDD (Mirrored Drive Doors) Teardown: passo 30, imagem 1 %32 Powermac G4 MDD (Mirrored Drive Doors) Teardown: passo 30, imagem 2 %32
    • This is also the notoriously loud AcBel 400W "Windtunnel" power supply
  31. Powermac G4 MDD (Mirrored Drive Doors) Teardown, CPU Heatsink: passo 31, imagem 1 %32
    • Now, remove these three Phillips screws:
    • As there are two Phillips screws well, there are two that you can see in the photo, but you want to remove the screws that are behind them.
  32. Powermac G4 MDD (Mirrored Drive Doors) Teardown: passo 32, imagem 1 %32 Powermac G4 MDD (Mirrored Drive Doors) Teardown: passo 32, imagem 2 %32
    • Now, lift the heatsink up off the computer, it is pretty heavy, because it's a giant block of aluminum.
    • Be careful when holding it, the edges can be sharp, making it likely to get cut if you hold it wrong!
    • As you may be able to tell, i have applied a replacement coat of Arctic Silver 5 to keep my MDD cooler than the stock paste, it really does a great job too!
  33. Powermac G4 MDD (Mirrored Drive Doors) Teardown: passo 33, imagem 1 %32 Powermac G4 MDD (Mirrored Drive Doors) Teardown: passo 33, imagem 2 %32
    • The incredibly large heatsink, this thing is 5 Lbs of solid aluminum. Just like every other part in this, and many other Macs, the heatsink is made by: ...you guessed it, Foxconn.
    • Before reinstalling, ensure that you clean the old thermal paste off of the heatsink with alcohol.
  34. Powermac G4 MDD (Mirrored Drive Doors) Teardown, Powermac G4 MDD (Mirrored Drive Doors) Teardown: passo 34, imagem 1 %32 Powermac G4 MDD (Mirrored Drive Doors) Teardown, Powermac G4 MDD (Mirrored Drive Doors) Teardown: passo 34, imagem 2 %32 Powermac G4 MDD (Mirrored Drive Doors) Teardown, Powermac G4 MDD (Mirrored Drive Doors) Teardown: passo 34, imagem 3 %32
    • The Powermac G4 MDD's, Guts Spilled On My Desk:
  35. Powermac G4 MDD (Mirrored Drive Doors) Teardown: passo 35, imagem 1 %32
    • The PowerMac G4 MDD Complete With Pro Speakers, 17" Studio Display, Mighty Mouse And Keyboard, Runs Leopard Server and Ubuntu 9 Beautifully.
Chris Green
Membro desde: 10/11/09
37.014 Reputação
Autoria de 49 guias
Equipe
Master Techs Membro de Master Techs
Community
Membros da 322
Autoria de 2.535 guias
7 comentários
Any idea if that heatsink can be used for a dual 1.42GHz board or must I get the copper heatsink?
nirv - Responder
Hi, thanks for the good job you do, I'm restoring my old G4 MDD and I wanted to know if it's possible for you to be able to install a 256gb ssd on this machine using a common sata - ide adapter. Does Leopard really run too? And how is the performance?
Carlo Sciarra - Responder
Hello, Carlo Sciarra. I'm sorry if this doesn't just respond to you directly. I am a little of an extreme apple fan, but I may be able to respond to you. As said, this is Apple's strongest Product in their G4 Line. If this is true, yes you can run Leopard on here. The 256GB SSD, you won't get your hands on a compatible SATA SSD for this because as far as I know there is no SATA Compatibility. I've never owned this product until today, so I don't know if it will run Leopard. It did release on August 31, 1999 after all. But, if that final picture is taken not being photoshopped or having the BIOS flashed in some way, it could very well work with Leopard. That's everything I have to say.
Cole Lindemulder -
Not sure you should refer to yourself as "a little of an extreme apple fan" if you think the G4 Mac MDD came out in '99.
While it is true the first gen of the G4 Mac came out in 1999, this version, essentially the 3rd generation G4 Mac, known as the Mirrored Drive Doors model, most definitely did not. Not only was it not released on the 31st of August as you say, but more importantly, it wasn't even released in 1999.
It wouldn't be until a few years AFTER the close of the 20th Century that the G4 Mac MDD would make its way to the public. Almost 3 years after, to be more precise. It was on the 13th of August (not the 31st) and it was in 2002, so not 1999, that the G4 Mac MDD was released.
Just thought I'd point that out to you. After all...Knowing is half the battle! #themoreyouknow🌈
Bipolar Curious -
I have a Sonnet PCI card that has 2x SATA ports & 1x UltraATA100 port. Currently is installed in my classic PM Dual 1.25G4 MDD. AFAIK, it will drive any SATA III device, such as a SSD... At this time I have only tested it with two old 2.5" SATA 5400rpm HDD's I pulled from some old laptops (320GB, 500GB) and they seem to work fine for data drives. I think I shall test some SSD's I have on hand to see if the card will recognize them. Would be nice, as any SATA SSD, would be faster than an ATA66 HDD.
Luke Rademacher - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 19
Últimos 30 dias: 80
Duração total: 27,845
