These shoes have been well worn and falling apart.
I was curious how they were constructed. I’ve seen complaints online about the electronics in these shoes stop working or the battery no longer charges.
I wanted to find out why and if there was a way to repair or provide feedback to the manufacturer.
I’m new to electronics and have never done a teardown before, feedback is welcomed.
Vídeo de Apresentação
Aprenda a consertar seu Shoe com este vídeo de apresentação.
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua Shoe, use o nosso manual de serviço .
I had already pulled apart the first shoe before filming.
When I went to pull apart the second one, I found that the last time the sole had been repaired, the bonding worked really really well.
This made it very difficult to pull the shoe apart. So instead I'll show the shoe I had already pulled apart.
Before getting to the electronics the common spots for these shoes to fail is:
The sole starts to lift from the platform,
The suede on the front of the toe rips and peels,
The ankle strap tears,
The toe strap tears.
The shoe works by charging with a micro USB next to the power button on the shank of the shoe.
The power button also cycles the colours and modes.
To protect the electronics, the shoes come with a warning to avoid excessive banging and moister.
The RGB LED light strip is glued to the platform.
The strip ran down the shank of the shoe and then wrapped around the shell containing the battery and board.
This board shell in held in place under the sole in the box of the platform. The plastic box was sealed with glue.
Warning: It was difficult to remove the glue that sealed the shell. The battery could have been damaged when removing it from the case.
The shell cracked, especially at the center, there's a clear indent from the chip in the middle of the board.
Unfortunately, after taking this shoe apart, while I was trying to take detail shots, the wire that connects to the button and USB charge port broke.
Incorporar este guia
Escolha um tamanho e copie o código abaixo para incorporar este guia como um pequeno widget no seu site / fórum.
Passo único
Guia completo
Pequeno - 600px
Médio - 800px
Grande - 1200px
Pré-Visualização
