Ir para o conteúdo principal
O que você precisa
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua Picstart Plus Development Programmer, use o nosso manual de serviço.
  1. Picstart Plus Development Programmer Teardown, Picstart Plus Development Programmer Teardown: passo 1, imagem 1 %32 Picstart Plus Development Programmer Teardown, Picstart Plus Development Programmer Teardown: passo 1, imagem 2 %32 Picstart Plus Development Programmer Teardown, Picstart Plus Development Programmer Teardown: passo 1, imagem 3 %32
    • Remove 4 Phillips screws located on the back side of the holding plate.
    • After the screws are removed, remove the case of the development programmer.
    • Carefully take out the circuit board with component side facing up. Put the case aside.
  2. Picstart Plus Development Programmer Teardown: passo 2, imagem 1 %32 Picstart Plus Development Programmer Teardown: passo 2, imagem 2 %32
    • Disconnect the microcontroller module from the main board using a spudger or a similar tool.
    • Set the microcontroller module aside.
  3. Picstart Plus Development Programmer Teardown: passo 3, imagem 1 %32 Picstart Plus Development Programmer Teardown: passo 3, imagem 2 %32
    • Flip over the mainboard so that the component side is facing down and remove the small Pan head screws that holds the cover of the IC holder
    • Remove the cover of the IC holder.
  4. Picstart Plus Development Programmer Teardown: passo 4, imagem 1 %32 Picstart Plus Development Programmer Teardown: passo 4, imagem 2 %32
    • Remove the IC holder lever along with the small metal plate that covers the lever.
    • Set the lever and the lever cover aside.
  5. Picstart Plus Development Programmer Teardown: passo 5, imagem 1 %32
    • Congratulations! You have completely dismantled the PICSTART Plus Development Programmer!
    • All the extracted components are shown in the picture.
Brad
Membro desde: 11/17/13
656 Reputação
Autoria de 2 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 28
Ao todo: 2,730
