Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Loja
Ferramentas utilizadas neste teardown
Introdução
How to open the device and what you'll find inside.
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua Philips Bluetooth adapter AEA2700, use o nosso manual de serviço.
  1. here you can see the view from the top, the bottom and the backface - device is really tiny: only 7,5cm in diameter! here you can see the view from the top, the bottom and the backface - device is really tiny: only 7,5cm in diameter! here you can see the view from the top, the bottom and the backface - device is really tiny: only 7,5cm in diameter!
    • here you can see the view from the top, the bottom and the backface - device is really tiny: only 7,5cm in diameter!
  2. Remove 2 of the rubbers on the bottom side - you'll find 2 screws afterwards>> unscrew them ;) Remove 2 of the rubbers on the bottom side - you'll find 2 screws afterwards>> unscrew them ;)
    • Remove 2 of the rubbers on the bottom side - you'll find 2 screws afterwards>> unscrew them ;)
  3. now simply remove the top cover.
    • now simply remove the top cover.
  4. there's only one external component connected by cable: the NFC tag
    • there's only one external component connected by cable: the NFC tag
    • it's easily possible to remove the circuit
    • lift it on the front side of the device
    • and pull it this direction - it helps to push at the cinch connector!
  5. Front- and backview of the circuit Front- and backview of the circuit
    • Front- and backview of the circuit
  6. when reassembling take care to stick the NFC tag to the correct location in the cover
    • when reassembling take care to stick the NFC tag to the correct location in the cover
RFischer
Membro desde: 29/12/2014
265 Reputação
2 Guias de autoria
Hello. Is there any way to use this device in a car through an adapter or modification?
Fabio Passarelli - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 7
Duração total: 3,500
