Ir para o conteúdo principal
O que você precisa
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua Panasonic EB TX320ASW, use o nosso manual de serviço.
  1. Panasonic EB TX320ASW Teardown, Panasonic EB TX320ASW Teardown: passo 1, imagem 1 %32 Panasonic EB TX320ASW Teardown, Panasonic EB TX320ASW Teardown: passo 1, imagem 2 %32
    • To remove the faceplate, pry the top of faceplate away from the phone. Follow snaps down, until faceplate is completely popped off.
  2. Panasonic EB TX320ASW Teardown: passo 2, imagem 1 %32
    • To remove battery push clip in; battery will pop out.
  3. Panasonic EB TX320ASW Teardown: passo 3, imagem 1 %32
    • Using a Star 3.0 bit, remove 4 screws in battery compartment.
  4. Panasonic EB TX320ASW Teardown: passo 4, imagem 1 %32 Panasonic EB TX320ASW Teardown: passo 4, imagem 2 %32
    • To separate front of phone from the back; start prying from bottom and work up the side. The phone should then pop apart.
  5. Panasonic EB TX320ASW Teardown: passo 5, imagem 1 %32
    • To remove keypad, turn front of phone over and let keypad fall out. All keys are connected by one rubber section.
    • If a button had been ripped off your keypad, you can replace the entire rubber keypad at this step and reassemble phone.
  6. Panasonic EB TX320ASW Teardown: passo 6, imagem 1 %32 Panasonic EB TX320ASW Teardown: passo 6, imagem 2 %32 Panasonic EB TX320ASW Teardown: passo 6, imagem 3 %32
    • To remove main-board from phone grab side of phone and pry upwards. Board should snap out.
  7. Panasonic EB TX320ASW Teardown: passo 7, imagem 1 %32
    • To remove speaker cover, pull out silver plate.
  8. Panasonic EB TX320ASW Teardown: passo 8, imagem 1 %32 Panasonic EB TX320ASW Teardown: passo 8, imagem 2 %32
    • After silver plate is removed, power button sits freely. Speaker can be removed by pulling up on it.
    • If your speaker went out it can easily be replaced in this step with a new one, then reassemble phone after this step.
  9. Panasonic EB TX320ASW Teardown: passo 9, imagem 1 %32 Panasonic EB TX320ASW Teardown: passo 9, imagem 2 %32
    • To remove keyboard circuit press on the middle and slide down. The board will pop up allowing for removal.
  10. Panasonic EB TX320ASW Teardown: passo 10, imagem 1 %32 Panasonic EB TX320ASW Teardown: passo 10, imagem 2 %32 Panasonic EB TX320ASW Teardown: passo 10, imagem 3 %32
    • To remove main-board from bracket, gently apply pressure to the four small clips. Board will pop out freely.
  11. Panasonic EB TX320ASW Teardown: passo 11, imagem 1 %32 Panasonic EB TX320ASW Teardown: passo 11, imagem 2 %32
    • To remove LCD screen pry back on highlighted clip and pull screen out. The screen will then pull up and out.
    • If the LCD screen went out, or was cracked somehow, replace with a new LCD screen and then reassemble phone from this step.
Andrew Foss
Membro desde: 10/04/11
10 Reputação
Autoria de 1 guia
Equipe
UW Stout, Team 5-2, Zhou Fall 2011 Membro de UW Stout, Team 5-2, Zhou Fall 2011
UWSTOUT-ZHOU-F11S5G2
Membros da 2
1 Guia de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Duração total: 3,468
