Ir para o conteúdo principal
O que você precisa
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua Palm IIIc, use o nosso manual de serviço.
  1. Palm IIIc Teardown, Removing broken LCD screen: passo 1, imagem 1 %32
    • Keep track of all pieces removed from the device.
    • Gently pull off the device cover. The cover snaps on and off easily where the cover attaches to the Palm IIIc device
  2. Palm IIIc Teardown: passo 2, imagem 1 %32
    • Using a Phillips head screwdriver, take out the four screws on the back of the device. You may have to pull them out with your hands once they are unscrewed.
    • There will be two long screws and two short screws. The long screws come from the top of the device, and the short screws come from the bottom of the device.
  3. Palm IIIc Teardown, Remove the Front and Back Covers: passo 3, imagem 1 %32
    • Using a spudger, carefully pry open the front and back covers along the side seam.
    • A small sensor cover will fall out when the front and back covers are removed. Keep track of it.
  4. Palm IIIc Teardown, Palm IIIc Teardown: passo 4, imagem 1 %32
    • Unhook battery cable from the motherboard and remove the battery.
  5. Palm IIIc Teardown: passo 5, imagem 1 %32 Palm IIIc Teardown: passo 5, imagem 2 %32
    • Behind the motherboard remove the brown plastic clamp and remove the front screen cover.
  6. Palm IIIc Teardown: passo 6, imagem 1 %32 Palm IIIc Teardown: passo 6, imagem 2 %32
    • Unhook the blue and red screen cables.
  7. Palm IIIc Teardown: passo 7, imagem 1 %32 Palm IIIc Teardown: passo 7, imagem 2 %32 Palm IIIc Teardown: passo 7, imagem 3 %32
    • Pop out the other two brown plastic clamps to release the screen and buttons.
  8. Palm IIIc Teardown: passo 8, imagem 1 %32
    • The black clips on the edges of the device (see picture) must be unclipped to remove the motherboard.
    • Carefully remove the motherboard from the device, pulling the motherboard away from the clips.
  9. Palm IIIc Teardown: passo 9, imagem 1 %32
    • Pull the screen out from the front.
  10. Palm IIIc Teardown: passo 10, imagem 1 %32
    • The object is now fully disassembled.
Paulina Trujillo
Membro desde: 04/07/11
265 Reputação
Autoria de 8 guias
Equipe
Cal Poly, Team 20-69, Walters Spring 2011 Membro de Cal Poly, Team 20-69, Walters Spring 2011
CPSU-WALTERS-S11S20G69
Membros da 5
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 10
Duração total: 4,926
