O que você precisa
Unplug your device and take out the battery
Slide the locked switch to the unlock position.
Remove the screws from the HDD and RAM compartment
Then remove the cover for the compartment, and use a pry tool if necessary
Ferramenta utilizada nesse passo:Tweezers$4.99
Use some tweezers to remove both the black and white cable connecting to the wifi module, and wiggle them back and forth if needed. The cables connect upwards so don't move them towards the sides only rotate if wiggling
To finish with the wifi module just unscrew the 1 screw located on the module, then pull it out.
Remove all screws in the HDD&RAM compartment and all screws in the battery compartment
There are little clips peppered along to top of the keyboard push them in then use a pry tool to keep the keyboard up.
Lift up the keyboard and disconnect the ribbon cable
And, TaDa! You removed the keyboard and got so far into this teardown, there's not a lot to go so keep going!
Remove all screws labelled "5L" and keep them seperate
Use a pry tool along the edges to remove the top main body
