Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Peças e ferramentas
  1. Unscrew 8 side screws (flat 2.4mm or dedicated torx), then of the 4 rear screws (hex 1.5mm).
    • Unscrew 8 side screws (flat 2.4mm or dedicated torx), then of the 4 rear screws (hex 1.5mm).
  2. Remove the front of the phone, disconnecting the LED connector. Remove the front of the phone, disconnecting the LED connector. Remove the front of the phone, disconnecting the LED connector.
    • Remove the front of the phone, disconnecting the LED connector.
  3. Kits para Nintendo Switch
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  4. Remove the 5 screws (Phillips #0) on the black support.
    • Remove the 5 screws (Phillips #0) on the black support.
    • Remove the black support.
  5. remove the 3 screws (Phillips #0) supporting the PCB.
    • remove the 3 screws (Phillips #0) supporting the PCB.
    • Disconnect the antenna on the right.
    • Disconnect the ZIF connector on the left.
    • Disconnect the ZIF connector at the top.
    • Disconnect the two connectors (battery) at the bottom.
  6. Withdraw the jammed SIM card. Withdraw the jammed SIM card.
    • Withdraw the jammed SIM card.
Conclusão
Um agradecimento especial a esses tradutores:
100%
Estes tradutores estão nos ajudando a consertar o mundo! Quer contribuir?
Comece a traduzir ›
Steve Muller
Membro desde: 14-05-2018
178 Reputação
2 Guias de autoria
Any idea how to remove the screen? Just Broke mine and cant find the phone for sale anywhere… and not screen with frame either, just the glass by itself…
hestbruden483 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 29
Duração total: 392
