Ferramentas utilizadas neste teardown
Introdução
In today's teardown, we will be cracking open the white plastic dock that came with the Original iPhone. The dock works only with the original iPhone. However, by removing the top cover of the dock, you can use the dock with other Apple products that have a 30 pin connector. In this teardown, you can modify the dock to be universal.
WARNING: THIS DISASSEMBLY WILL VOID YOUR DOCK'S WARRANTY.
The Original iPhone dock!
This dock only holds the original iPhone. It will not hold the iPhone 3G/3GS as it is wider and thicker.
