Ir para o conteúdo principal
O que você precisa
Vídeo de Apresentação
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua OnePlus 7 Pro, use o nosso manual de serviço.
    Considerações finais
    • The battery can be removed first, once you open the phone. It’s only lightly adhered and comes with a pull tab for easy removal.
    • Many components are modular and can be individually replaced.
    • Display replacements, which are the most common repairs, are not prioritized in the design. (You have to completely disassemble the phone to swap out your screen.)
    • While the Front Facing Camera’s new pop up ability is really cool, the added mechanical element makes it more likely to wear out and more complicated to replace.
    • The primary access point for all repairs, the rear panel, is firmly glued in place.
    Índice de reparabilidade
    4
    Reparabilidade 4 de 10
    (10 é o mais fácil de reparar)
6 comentários
What is the best way to get rid of slider?
Can it be cut from outside w/o unglue back cover?
Bob Monkas - Responder
Slider? Do you mean the pop up camera? If so, removing it is major surgery, cannot be done from the outside.
Forge -
Can I replace the 256 memory module? Need to salvage some things on it.
vishal.shah.tx - Responder
OnePlus 7 pro 8/256
Anita Jajoriya -
do i need to remove the pop up camera if i want to change the screen?
romain.collet - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 12
Últimos 7 dias: 63
Últimos 30 dias: 352
Duração total: 70,217
