Introdução
O que você precisa
Vídeo de Apresentação
- There are no proprietary screws.
- The OnePlus 5’s display is held on by easy to dispatch reusable plastic clips.
- Most components such as the cameras and USBC/headphone jack flex cable are modular and easy to access.
- The battery has a pull tab making removal easy, but the motherboard must be removed to access it.
- The display and glass are fused and the home button is integrated into the display assembly making repair of all three of these parts more complicated and expensive.
Considerações finais
Índice de reparabilidade
7
Reparabilidade 7 de 10
(10 é o mais fácil de reparar)
16 comentários
Wow!! it is good, thank you.
Kaye - Responder
Wonderful video as usual. If one were to take theirs apart would it be as 'tight' once it was back together?
I think the buttons edges are a little sharp and I'm tempted to take it apart to put a little bevel on them.
I'd like it if the screen didn't end up being loose or have gaps around the back cover.
David - Responder
Is there an audio DAC founded? Can you tell us wich is it?
David Sepúlveda - Responder
The Snapdragon 835 has a built in DAC+amp with up to 4W output. https://www.qualcomm.com/products/snapdr...
George A. -
for those who dont have yootube and chance of a standard layout detaillng this teardown...?
P Stephenson - Responder
Link for screen please? My screen is broken and I need one but can't find the screen for OnePlus 5 in iFixit store!
Cheikh Alyounis - Responder
I appreciate the video, but I like ifixit for the manual-like write-ups. If I am ever unfortunate enough to have to tear mine down, I will make one.
Zack Westlie - Responder
Is there a +5V point on the board that is equivalent to the +5V from the charging port? Asking to decide whether or not we can solder a qi wireless coil in.
Azrudi Mustapha - Responder
my power button broken. the phone kept on off and on by itself
Azriff Reza - Responder
mine the power button gave way.. the phone kept on on and off by itself
I have a problem with my wifi conections form Oneplus 5 …where is the wifi positioned in the phone? please help..
DouaPuncte G - Responder
Is the 5T equally easy to repair? Or harder?
Suchiththa Wickremesooriya - Responder
Is there a major difference between the 5 and the 5T?
Is the OnePlus 5T much different from the OnePlus 5?
THX1138 - Responder
This video really sucks. It’s cut way to fast, you just don’t see anywhere how disassembly is done. Instead the talk is just advertising the phone.
JPT - Responder
The ‘Final Thoughts’ above has this:
I’ve just changed my home button/fingerprint sensor (thanks ifixit!) and it just presses out with just a bit of careful pressure on each side. It’s not integrated.
BTW, none of the repair guides mentioned that you need to put double sided tape or other suitable adhesive on the back of the replacement button before pressing it into place.
David Hoffman - Responder
