Ir para o conteúdo principal
O que você precisa
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua OWC Thunderbolt 3 Pro Dock, use o nosso manual de serviço.
  1. OWC Thunderbolt 3 Pro Dock Teardown, The start: passo 1, imagem 1 %32 OWC Thunderbolt 3 Pro Dock Teardown, The start: passo 1, imagem 2 %32 OWC Thunderbolt 3 Pro Dock Teardown, The start: passo 1, imagem 3 %32
    • Flip dock upside down and remove rubber feet
  2. OWC Thunderbolt 3 Pro Dock Teardown, Removing bottom cover: passo 2, imagem 1 %32 OWC Thunderbolt 3 Pro Dock Teardown, Removing bottom cover: passo 2, imagem 2 %32 OWC Thunderbolt 3 Pro Dock Teardown, Removing bottom cover: passo 2, imagem 3 %32
    • Remove bottom plate screws and remove bottom plate
    • Make sure to use a TORX TR8 head for the bottom screws
  3. OWC Thunderbolt 3 Pro Dock Teardown, Removing the mainboard: passo 3, imagem 1 %32 OWC Thunderbolt 3 Pro Dock Teardown, Removing the mainboard: passo 3, imagem 2 %32 OWC Thunderbolt 3 Pro Dock Teardown, Removing the mainboard: passo 3, imagem 3 %32
    • Remove the mainboard and its three screws
    • Use a TORX TR8 for all of these screws
    • Make sure to unplug the fan on the other side as it is still connected to the chassis, it may need some persuasion as the connector is really in there
    • When removing the mainboard be gentle as the front I/O sits flush to the chassis otherwise you might damage it.
  4. OWC Thunderbolt 3 Pro Dock Teardown, Removing top plate: passo 4, imagem 1 %32 OWC Thunderbolt 3 Pro Dock Teardown, Removing top plate: passo 4, imagem 2 %32 OWC Thunderbolt 3 Pro Dock Teardown, Removing top plate: passo 4, imagem 3 %32
    • Remove the four TORX TR8 screws
    • Pry the top plate away from the main chassis, this may take some persuasion as the top plate is glued in a bit
  5. OWC Thunderbolt 3 Pro Dock Teardown, Removing NIC heatsink: passo 5, imagem 1 %32 OWC Thunderbolt 3 Pro Dock Teardown, Removing NIC heatsink: passo 5, imagem 2 %32
    • Remove the two TORX TR8 screws to remove the heatsink
    • It is highly recommended to clean the surface from whatever residue the thermal pad has left behind to increase longevity of the dock
  6. OWC Thunderbolt 3 Pro Dock Teardown, Removing fan: passo 6, imagem 1 %32 OWC Thunderbolt 3 Pro Dock Teardown, Removing fan: passo 6, imagem 2 %32 OWC Thunderbolt 3 Pro Dock Teardown, Removing fan: passo 6, imagem 3 %32
    • Switch to a TORX TR10 bit for the fan screws
    • The fan model is a sunon HA40101V4-1D070-G99
    • When the screws are out the fan should just fall out
  7. OWC Thunderbolt 3 Pro Dock Teardown, Everything spread out: passo 7, imagem 1 %32
  8. OWC Thunderbolt 3 Pro Dock Teardown, A look at half of the mainboard: passo 8, imagem 1 %32 OWC Thunderbolt 3 Pro Dock Teardown, A look at half of the mainboard: passo 8, imagem 2 %32 OWC Thunderbolt 3 Pro Dock Teardown, A look at half of the mainboard: passo 8, imagem 3 %32
    • sample text, the photos speak for themselves
    • The 10Gbe NIC is the Aquantia AQC107S-B1-C
  9. OWC Thunderbolt 3 Pro Dock Teardown, A look at the other half: passo 9, imagem 1 %32 OWC Thunderbolt 3 Pro Dock Teardown, A look at the other half: passo 9, imagem 2 %32
    • Insert wisdom here. - indeed
  10. OWC Thunderbolt 3 Pro Dock Teardown, Measurements of the NIC: passo 10, imagem 1 %32 OWC Thunderbolt 3 Pro Dock Teardown, Measurements of the NIC: passo 10, imagem 2 %32
    • I cant figure out how to put more than 3 pics in one step, so the ended up here.
  11. OWC Thunderbolt 3 Pro Dock Teardown, Putting the heatsink back: passo 11, imagem 1 %32 OWC Thunderbolt 3 Pro Dock Teardown, Putting the heatsink back: passo 11, imagem 2 %32 OWC Thunderbolt 3 Pro Dock Teardown, Putting the heatsink back: passo 11, imagem 3 %32
    • Support the heatsink and line it up with the holes on the top of the chassis
    • Re-install the two TORX TR8 screws to hold in the heatsink
  12. OWC Thunderbolt 3 Pro Dock Teardown, Re-installing fan: passo 12, imagem 1 %32 OWC Thunderbolt 3 Pro Dock Teardown, Re-installing fan: passo 12, imagem 2 %32
    • Line up the fan with the holes
    • Screw the fan back in with the TORX TR10 screws
  13. OWC Thunderbolt 3 Pro Dock Teardown, Re-installing the top lid: passo 13, imagem 1 %32 OWC Thunderbolt 3 Pro Dock Teardown, Re-installing the top lid: passo 13, imagem 2 %32
    • Line up the top lid with the main chassis, make sure to have the fan vent in the correct orientation so it can breathe.
    • Screw the lid back in with the four TORX TR8 screws
  14. OWC Thunderbolt 3 Pro Dock Teardown, Re-installing mainboard: passo 14, imagem 1 %32 OWC Thunderbolt 3 Pro Dock Teardown, Re-installing mainboard: passo 14, imagem 2 %32 OWC Thunderbolt 3 Pro Dock Teardown, Re-installing mainboard: passo 14, imagem 3 %32
    • Put the mainboard back into the main chassis, make sure to be gentile and line up the rear I/O first and then slowly lower in the other side.
    • Secure the mainboard with the 3 TORX TR8 screws. - no you arent missing any the rest of the screws go through the bottom cover
  15. OWC Thunderbolt 3 Pro Dock Teardown: passo 15, imagem 1 %32 OWC Thunderbolt 3 Pro Dock Teardown: passo 15, imagem 2 %32 OWC Thunderbolt 3 Pro Dock Teardown: passo 15, imagem 3 %32
    • Line up the bottom cover, !make sure to use the orientation that is shown in the photo otherwise it will not line up!
    • Secure the bottom cover with the four TORX TR8 screws
    • Re-install the rubber feet, you might want to put a bit of glue on these to keep them on when moving around
Robust
Membro desde: 04/26/21
688 Reputação
Autoria de 3 guias
Equipe
CV22 Membro de CV22
Community
1 Membro
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 75
Duração total: 240
