Introdução
In detail teardown. I guess
O que você precisa
Remove the mainboard and its three screws
Make sure to unplug the fan on the other side as it is still connected to the chassis, it may need some persuasion as the connector is really in there
Pry the top plate away from the main chassis, this may take some persuasion as the top plate is glued in a bit
Support the heatsink and line it up with the holes on the top of the chassis
Line up the top lid with the main chassis, make sure to have the fan vent in the correct orientation so it can breathe.
Secure the mainboard with the 3 TORX TR8 screws. - no you arent missing any the rest of the screws go through the bottom cover
