Introdução
In this guide, we will walk you through disassembling a Nokia N900 through techniques, tips, and advice.
O que você precisa
Once all six screws have been removed, gently pull the phone apart. You should now be left with two pieces.
Be aware when doing this step as the LCD flat-flex cable is still connected to the mainboard, disconnect the cable first before pulling it apart!
With the touch screen now removed from the keyboard slider, use the blue, plastic opening tool to remove the cover of the screen.
It is highly advised to take off one side at a time.
Once one section of the cover has been removed, the second cover will be removable. You have officially completed tearing down a Nokia N900.
Um comentário
Looks like the LCD flex cable ripped off on this teardown, ouch!
