Ir para o conteúdo principal
O que você precisa
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua Nokia 8 Sirocco, use o nosso manual de serviço.
  1. Nokia 8 Sirocco Teardown, Back glass removal: passo 1, imagem 1 %32 Nokia 8 Sirocco Teardown, Back glass removal: passo 1, imagem 2 %32 Nokia 8 Sirocco Teardown, Back glass removal: passo 1, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Plastic Cards
    $2.99
    Comprar
    • Start by heating up the back glass. Ifixit's iOpener kit is very useful here. You can also use heating pad or heat gun
    • Take off the SIM tray, and start there. Use suction cup if avaliable
    • After you have made room for plastic card, finish the work by going around the glass with card
  2. Nokia 8 Sirocco Teardown, Midframe: passo 2, imagem 1 %32 Nokia 8 Sirocco Teardown, Midframe: passo 2, imagem 2 %32 Nokia 8 Sirocco Teardown, Midframe: passo 2, imagem 3 %32
    • Start by screwing off all screws. There are 3 type of different screws.
    • 11 pcs of longer black painted screws
    • 10 pcs of shorter black painted screws
    • 1 shiny metallic screw
    • After that, pop off bottom piece and then midframe
    i suppose 3rd screw from the bottom on right side (bottom view) is long one, right?
    atrushan - Responder
  3. Nokia 8 Sirocco Teardown, Battery: passo 3, imagem 1 %32 Nokia 8 Sirocco Teardown, Battery: passo 3, imagem 2 %32 Nokia 8 Sirocco Teardown, Battery: passo 3, imagem 3 %32
    • Remeber to disconnect battery connector first
    • Battery has pull tabs, so you should try this first
    • If pull tab breaks, you have to commit a pry of shame
  4. Nokia 8 Sirocco Teardown, Daughter board: passo 4, imagem 1 %32 Nokia 8 Sirocco Teardown, Daughter board: passo 4, imagem 2 %32 Nokia 8 Sirocco Teardown, Daughter board: passo 4, imagem 3 %32
    • Disconnect volume and power button connector
    • Disconnect connector on motherboard
    • Pry off the daughter board
  5. Nokia 8 Sirocco Teardown, Motherboard: passo 5, imagem 1 %32 Nokia 8 Sirocco Teardown, Motherboard: passo 5, imagem 2 %32 Nokia 8 Sirocco Teardown, Motherboard: passo 5, imagem 3 %32
    • There are 2 screws
    • 1 longer black screw
    • 1 standoff screw
    • After taking the screws off, you can disconnect antenna coaxial cables
    • Now you can take motherboard off
    • Make sure to push SIM-eject pin out first
  6. Nokia 8 Sirocco Teardown, Charging board: passo 6, imagem 1 %32 Nokia 8 Sirocco Teardown, Charging board: passo 6, imagem 2 %32
    • Charging board is held down with 2 screws
    • 1 black screw
    • 1 golden screw
    • After taking the screws off, charging board is free
    • And now you are done, repeat steps backward to put everything back together
Mobile Partners
Membro desde: 02/22/20
204 Reputação
Autoria de 1 guia
2 comentários
Mannaia Dio, mi ruvinasti!
Giuseppe Barbieri - Responder
Mannaia God, You ruined me!
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 28
Duração total: 3,249
