Pular para o conteúdo principal
Introdução
In this tutorial, I will show you how to disassemble the Nokia 3210.
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua Nokia 3210, use o nosso manual de serviço.
  1. Remove Battery cover, battery and SIM Card.
    • Remove Battery cover, battery and SIM Card.
  2. Remove the antenna with your fingers.
    • Remove the antenna with your fingers.
  3. Remove these screws. These are Torx T6. You'll need this screwdriver to remove them.
    • Remove these screws. These are Torx T6. You'll need this screwdriver to remove them.
  4. iPhone X Fix Kits
    Warranty up? No worries, we’ve got the fix.
    Comprar agora
    iPhone X Fix Kits
    Comprar agora
  5. If you remove the plate, you can see the Motherboard. Remove the Motherboard with a small flathead screwdriver or a spudger. (A spudger is recommended).
    • If you remove the plate, you can see the Motherboard. Remove the Motherboard with a small flathead screwdriver or a spudger. (A spudger is recommended).
  6. Here's the PCB with removed EMI shields.
    • Here's the PCB with removed EMI shields.
    • CCONT NMP70467 Power Management IC
    • NMP0581 Power Supply IC
    • BGY252 and BGY 262 UHF Amplifier
  7. Other side of the PCB.
    • Other side of the PCB.
    • Hitachi HWYN202A 900MHz Duplexer
    • Intel F160B3TA Flash
    • Atmel 24C128 EPROM
    • Samsung KM68U1000 SRAM
    • Buzzer MZT-03C
    • Texas Instruments MAD2PRI Microcontroller (ARM Based)
  8. Disassembly Completed!
    • Disassembly Completed!
Bryan
Membro desde: 27-10-2012
690 reputação
5 Guias de autoria
yaaaaas queeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeen
Gaubrisco - Responder
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 15
Todo: 4,758
