Ir para o conteúdo principal
O que você precisa
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua Nintendo Wii Remote, use o nosso manual de serviço.
  1. Nyko Wand Teardown, Removing battery cover and back plate: passo 1, imagem 1 %32 Nyko Wand Teardown, Removing battery cover and back plate: passo 1, imagem 2 %32 Nyko Wand Teardown, Removing battery cover and back plate: passo 1, imagem 3 %32
    • First flip controller so that the back plate faces you
    • Remove the battery cover by pushing up on the bottom plate
  2. Nyko Wand Teardown: passo 2, imagem 1 %32 Nyko Wand Teardown: passo 2, imagem 2 %32
    • Remove both batteries if their are any inside the remote .
    • To remove them press down on the positive end then pull to take out
  3. Nyko Wand Teardown: passo 3, imagem 1 %32 Nyko Wand Teardown: passo 3, imagem 2 %32
    • Using the tri-point Y1 Screw driver remove the two center screws by turning counter clock wise
    • Repeat process for bottom two
  4. Nyko Wand Teardown: passo 4, imagem 1 %32 Nyko Wand Teardown: passo 4, imagem 2 %32 Nyko Wand Teardown: passo 4, imagem 3 %32
    • To fully take off the back piece you will have to use your flat head screw driver and gently go along the edge and unclip it.
    • Gently pull out the whole circuit board ( be careful you may break or rip a wire if you pull to hard )
    • {CAUTION :WATCH OUT FOR SMALL PARTS}
  5. Nyko Wand Teardown: passo 5, imagem 1 %32 Nyko Wand Teardown: passo 5, imagem 2 %32 Nyko Wand Teardown: passo 5, imagem 3 %32
    • To remove the buttons you will simply have to take off the grey silicon cover.
    • To remove the small speaker you can simply pull up .
    • CAUTION : FOR SMALLER BUTTONS LIKE THE VOLUME ONES .
  6. Nyko Wand Teardown: passo 6, imagem 1 %32 Nyko Wand Teardown: passo 6, imagem 2 %32
    • Gently pry the buttons upwards ,removing the buttons from its holding slot.
    • CAUTION : WATCH OUT FOR SMALL BUTTONS !
    • IF YOU WANT TO REBUILD IT FOLLOW STEPS 1-7 BACKWORDS.
Demian De La Vega
Membro desde: 04/17/19
143 Reputação
Autoria de 1 guia
Um comentário
good¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡
RIGO NOLASCO - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 26
Duração total: 2,389
