Ir para o conteúdo principal
O que você precisa
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua Nintendo WaveBird Wireless Controller, use o nosso manual de serviço.
  1. Nintendo WaveBird Wireless Controller Receiver Teardown, Nintendo WaveBird Wireless Controller Receiver Teardown: passo 1, imagem 1 %32 Nintendo WaveBird Wireless Controller Receiver Teardown, Nintendo WaveBird Wireless Controller Receiver Teardown: passo 1, imagem 2 %32
    • This is the connector side of the WaveBird receiver.
    • Remove two tri-wing screws, and separate the black and gray halves of the receiver.
  2. Nintendo WaveBird Wireless Controller Receiver Teardown: passo 2, imagem 1 %32 Nintendo WaveBird Wireless Controller Receiver Teardown: passo 2, imagem 2 %32
    • Remove four tri-wing screws to remove the connector from the housing.
  3. Nintendo WaveBird Wireless Controller Receiver Teardown: passo 3, imagem 1 %32 Nintendo WaveBird Wireless Controller Receiver Teardown: passo 3, imagem 2 %32 Nintendo WaveBird Wireless Controller Receiver Teardown: passo 3, imagem 3 %32
    • Insert wisdom here.
  4. Nintendo WaveBird Wireless Controller Receiver Teardown, Controller pinout: passo 4, imagem 1 %32
    • Red: 3.43V logic supply (pin 1 on cable)
    • Brown: Ground (pin 3 on cable)
    • Green: Data (pin 2 on cable, recessed by 2mm into connector)
    • Violet: Shield (pin 4 on cable)
  5. Nintendo WaveBird Wireless Controller Receiver Teardown: passo 5, imagem 1 %32 Nintendo WaveBird Wireless Controller Receiver Teardown: passo 5, imagem 2 %32
    • The PCB has a metal RF shield that protects the radio from interference from the game console; this extends the useful range of the controller.
    • One half of the shield is held on with friction clips; the other half must be desoldered.
  6. Nintendo WaveBird Wireless Controller Receiver Teardown: passo 6, imagem 1 %32
    • The IC is a custom (or relabeled) Nintendo chip marked "WCRX-DOL / T2.7488K1". ("Wireless Controller Receiver - Dolphin"). It is presumably a microcontroller that decodes signals from the radio and sends them to the console.
    • This 4-pin connector goes to the joypad connector on the GameCube.
    • Desolder these four points to remove the shield and expose the radio on the other side.
  7. Nintendo WaveBird Wireless Controller Receiver Teardown: passo 7, imagem 1 %32
    • The bottom side has all the RF circuitry -- the chip is a Nintendo chip marked "WR-DOL / H2102 / CG2710 / 02", presumably the radio.
    • EPCOS X6882 custom bandpass filter
    • Trim-pot for adjustment at the factory -- could be a frequency tweak or gain adjustment.
    • The rotary switch allows the user to choose a frequency to avoid interference with other devices.
    • The antenna is mounted directly on the PCB, inside the device.
bushing
Membro desde: 04/23/10
10.250 Reputação
Autoria de 13 guias
7 comentários
Hello. I have 2 receivers that only have three pins. Just below the Data pin there is nothing there...not as your pictures show. I bought a wavebird on ebay and it wont work. How can both of my receivers be missing a pin? I treat them like gold because I know these are not manufactured by Nintendo anymore. So it looks like the 2mm into connectors are missing. What? How?
cllonyx - Responder
The Wavebird receiver only needs 3.3volts, data and ground to operate so that's why there is only 3 pins.
If you gave more details on whats happening it would be much easier to diagnose the problem.
Ivan -
My receiver is dead I think. The controller is perfectly fine but the receiver light won't even come on. Any suggestions how to resurrect this receiver?
Stan Roy - Responder
Hello Stan!
I have opened the receiver and scratched the antena (in step 7) with a screwdriver because I saw it was very dark and some black dust came off. Now it works like new.
I also have found that some receivers won't work on the first port if they're on high frequencies and have no trouble if you dial down to the first five positions. I have no idea why but it works.
All the best!!
Fer -
So i was playing some games with my wavebird controller and went the morning after that for a couple of day on vacation. As soon as i came back i turned my gamecube on, but the Wavebird isnt working anymore. Tried out all the channels and ports, but the Receiver light wont light up anymore when i press a button. How do i fix this?
Fer mentioned earlier i need to scratch around my antenna in step 7. Does this really work?
Daniel6254 - Responder
Thank-you!!!
Fer Thank-you so much Its works now.
I used a flathead and Qtip to scratch off that dark dust and its works like new
I ended up to here to look more information about wavebird. My problem is that my controller cant keep buttons down for some time. I guess that the receiver miss the connection with the controller. Is this typical function and can that be fixed? I tied different pairing numbers but didnt have effect..
Juho Lampikoski - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 13
Últimos 30 dias: 88
Duração total: 18,473
