Ir para o conteúdo principal
O que você precisa
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua Nintendo DS Lite, use o nosso manual de serviço.
  1. Nintendo DS Lite Teardown, Part  Seperartion: passo 1, imagem 1 %32
    • Your first step would be to unscrew all all screws on the back and take the case off. You take the case off by placing a spudger on the line edges , and then place it inward, forcing it to separate the two parts.
  2. Nintendo DS Lite Teardown, WI-FI board: passo 2, imagem 1 %32
    • You first remove the gabbles by gently pulling them and do the same for the WI-FI board
  3. Nintendo DS Lite Teardown, Screen Removal: passo 3, imagem 1 %32
    • You take the mother board off by flipping the upside-down and the screen should pop right off.
  4. Nintendo DS Lite Teardown: passo 4, imagem 1 %32
    • Unscrew and gently slide wires through frame
  5. Nintendo DS Lite Teardown, Final Look: passo 5, imagem 1 %32
    • The DS should look like this and to put the DS back together simply follow steps back wards.
Isabella Sandoval
Membro desde: 11/06/16
182 Reputação
Autoria de 1 guia
1Comentário do guia
Don’t like this guide. Only a few steps. Tear downs usually have 50+. Add more and in detail.
Bob - Responder
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 25
Últimos 30 dias: 128
Ao todo: 3,228
