Introdução
In honor of the 20th anniversary of its release, I decided to give the Nintendo 64 a proper teardown, and take a look inside the legendary console that defined a generation.
O que você precisa
The Nintendo 64 was Nintendo's third home console. Released in 1996 for the US and Japan, the N64 boasted 64-bit graphics for the most realistic gaming experience ever made to date. The N64 was co-developed by Nintendo and Silicon Graphics.
NEC VR4300 64-bit CPU, running at 93.75 Mhz
Silicon Graphics Reality Coprocessor (RCP) GPU
576i (720×576) Composite output
Support for up to 4 players
Flip the console upright, and the top cover just comes right off.
Remove the 10 crossbar screws using a Philips #2 screwdriver.
Take out the 2 screws holding in one piece of the expansion slot shield, also with a Philips #2
The 2 black screws and the one at the bottom left of the expansion slot shield are easily removed with a Philips #2.
Finally, remove the 2 long screws from the 2 ends of the slot with a Philips #0.
The heatsink crossbar comes right off, which gives us access to the motherboard shield.
The 5 screws on the two sides of the shield are swiftly removed with a Philips #2
The 2 screws on each side of the Game Pak slot are quite long, and are removed with a Philips #2.
With that, the shield slips right off, letting us gaze at the Nintendo 64's source of power.
On the motherboard are 3 very pronounced steel blocks, which indicates that the important stuff is under there. But before removing these, it's best to take the motherboard out of the bottom case.
In order to remove the motherboard, unscrew the 4 Philips #2 screws from the two back I/O ports, allowing extraction of the motherboard.
4 comentários
Thank you, this tear down was real helpful. I was able to open up an N64 and clean the corrosion between some pins that kept it from turning on. :D
I’m really glad to hear that! The N64 has always had a special place in my heart since it was the first home console I ever had.
dang one in the same Christian same first console my second was the PlayStation 1(actually just called PlayStation) and the PlayStation 2 my third the Nintendo GameCube then handheld consoles the game boy, game boy advanced, and Nintendo 2dsi , and the Nintendo 3-DS, and then fourth the non-handheld online consoles the Wii and the Xbox 360.
This in my opinion was one of the best consoles. The Zelda games for the 64 were amazing. Love the idea I can fix mine.
