Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua Nikko La Nera Junior, use o nosso manual de serviço.
  1. The Car, the Remote Control and a Phillips screwdriver.
    • The Car, the Remote Control and a Phillips screwdriver.
  2. Let's start!
    • Let's start!
    • Remove this screw.
    • The rear wing
    • Unscrew this black screws
    • Remove the wing
    • The Exhausts
    • Remove these screws
    • Remove the exhausts
    • The Rear Cover
    • The "tubolar" body
    • Flip the car
    • Remove these screws.
    • Remove the body
    • The seat
    • Remove these screws (one of these is back of the seat)
    • Remove the seat.
    • The antenna
    • Remove this screw
    • Raise the circuit board
    • Remove the antenna
    • The "engine"
    • Remove the gears cover
    • Remove the engine block
    • Remove the gear and his hinge
    • Remove this piece of plastic
    • The Engine!
    • Remove the wheels from the car
    • The Steering Mechanism
    • Remove the cover
    • Lift the wheels
    • Remove the steering bar...
    • ...the two screws...
    • ...and the cover.
    • Remove the first "gear"...
    • ...and the second.
    • Remove the steering motor
    • Remove the plastic cover
    • Be careful!
      • Remove this piece
    • Remove the second piece...
    • ...and the spring.
    • Congratulations! The car is torn down!
    • Let's tear down the remote!
    • Remove the screw in the PCB
    • Remove the screw in the piece of plastic at the end of the antenna
    • Remove the plastic piece around the beginning of the antenna
    • Carefully de-route the antenna from the PCB
    • Detach the two parts of eat key.
    • Congratulations! You've ended the teardown!
Federico Barutto
286 reputação
2 Guides authored
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 8
Todo: 1,395
