Ir para o conteúdo principal
Nextbook Ares 8" Tablet Teardown
O que você precisa
  1. Nextbook Ares 8" Tablet Teardown, Remove back cover: passo 1, imagem 1 %32
    • Wedge between the frame and back cover with an isesamo and separate all of the retaining clips
  2. Nextbook Ares 8" Tablet Teardown, Disconnect battery: passo 2, imagem 1 %32 Nextbook Ares 8" Tablet Teardown, Disconnect battery: passo 2, imagem 2 %32
    • The connector slides out towards the outside of the device, and mine was pretty sticky so be careful.
  3. Nextbook Ares 8" Tablet Teardown, Disconnect screen assembly: passo 3, imagem 1 %32 Nextbook Ares 8" Tablet Teardown, Disconnect screen assembly: passo 3, imagem 2 %32 Nextbook Ares 8" Tablet Teardown, Disconnect screen assembly: passo 3, imagem 3 %32
    • Disconnect the LCD ribbon cable from the top and bottom of the battery. It is unnecessary to peel it off of the battery.
    • Disconnect the digi cable from the top right of the back of the device.
  4. Nextbook Ares 8" Tablet Teardown, Disconnect periphery flexes: passo 4, imagem 1 %32 Nextbook Ares 8" Tablet Teardown, Disconnect periphery flexes: passo 4, imagem 2 %32
    • Disconnect the camera flex
    • Disconnect the power/volume/home flex
  5. Nextbook Ares 8" Tablet Teardown, Remove the speaker assembly: passo 5, imagem 1 %32
    • Remove the 5 speaker assembly screws and pry off the assembly
    • At this point you can also lightly pull the battery away from the back of the LCD. There isn't much adhesive holding it in place.
  6. Nextbook Ares 8" Tablet Teardown, Remove the motherboard: passo 6, imagem 1 %32 Nextbook Ares 8" Tablet Teardown, Remove the motherboard: passo 6, imagem 2 %32
    • Remove the 5 motherboard screws and gently separate it from the back of the lcd.
    • At this point, the only thing left should be the display assembly
  7. Nextbook Ares 8" Tablet Teardown, Remove the LCD: passo 7, imagem 1 %32 Nextbook Ares 8" Tablet Teardown, Remove the LCD: passo 7, imagem 2 %32
    • Remove the 6 LCD screws and brackets
    • Gently separate the LCD from the frame
  8. Nextbook Ares 8" Tablet Teardown, Separate the glass from the frame: passo 8, imagem 1 %32 Nextbook Ares 8" Tablet Teardown, Separate the glass from the frame: passo 8, imagem 2 %32 Nextbook Ares 8" Tablet Teardown, Separate the glass from the frame: passo 8, imagem 3 %32
    • Use a heat gun or hot plate to separate the digitzer and glass from the frame
    • Before heating the frame its a good idea to remove the camera from the frame so it's not damaged.
  9. Nextbook Ares 8" Tablet Teardown, Complete!: passo 9, imagem 1 %32
    • Insert wisdom here.
Conclusão
12 outras pessoas executaram este guia.
Auburn Store
Membro desde: 01/17/16
463 Reputação
Autoria de 1 guia
8 comentários
The screen is crack the screen is on when I hit the home button it won't work
Hilda Silva - Responder
I replaced screen and now screen won't light up
ruger32016 - Responder
How can u get the whole tablet fixed when the screen came off and everything is not their in its place any more???
Cupcake - Responder
my touch screen does’nt respond can it be replace and where could i get one and what is the price. Im from mauritius thk
Alphonse Tonio - Responder
My touch screen does’nt respond is this can be change and where can i get one and what the price i’m from Mauritius
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 8
Duração total: 6,939
