Ferramentas utilizadas neste teardown
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua Nest Temperature Sensor, use o nosso manual de serviço.
  1. Nest Temperature Sensor is a complementary device for the Nest Thermostat E or 3rd gen. It is created to help customers measure the temperature exactly where needed and control the thermostat accordingly photo credit: John Miller/CNET
    • Nest Temperature Sensor is a complementary device for the Nest Thermostat E or 3rd gen. It is created to help customers measure the temperature exactly where needed and control the thermostat accordingly
      • photo credit: John Miller/CNET
    • Positioned as a premium device, this Sensor is made from quality soft-touch plastic and comes in a decent box
    • The Sensor uses a single CR2 battery (included)
    • Diameter: 50mm, height: 22mm
  2. The back of the Sensor has a simple screw, which gives us access to the battery The back of the Sensor has a simple screw, which gives us access to the battery
    • The back of the Sensor has a simple screw, which gives us access to the battery
  3. Free shipping on all orders over US$100,00 or containing a Pro Tech Toolkit!
    Visite Nossa Loja
  4. Removing 4 Torx T7 screws - and here it is - the PCB! The inner side of the battery holder has 2 contacts on it's sides The inner side of the battery holder has 2 contacts on it's sides
    • Removing 4 Torx T7 screws - and here it is - the PCB!
    • The inner side of the battery holder has 2 contacts on it's sides
  5. On The front we can spot Bluetooth antenna (on the board)
    • On The front we can spot
      • Bluetooth antenna (on the board)
      • Battery connectors
      • Murata 2x2mm RF switch connector, that can be used for RF testing
      • U11, U13 - probably some chips behind the shield, which is (unfortunately) firmly soldered. My guess: one of them is ultra-low power microcontroller and the other one is taking care of power delivery to the board
      • J1 - place for debug connector (empty in production)
  6. On the other side This clear place on the PCB is for the antenna on the other side nRF52832  BLE chip (maintains the only wireless connection of this device)
    • On the other side
      • This clear place on the PCB is for the antenna on the other side
      • nRF52832 BLE chip (maintains the only wireless connection of this device)
      • This is a tiny temperature sensor (not sure which one exactly)
      • The metal connector is a smart way to reinforce this tiny PCB
    • The sensor is on the edge, but still inside plastic case, and has no thermal channel to the outside (no vents or compound) - this fact rises a huge concern about the speed of the measurements
    • No temperature + humidity combo here, as seen in the Thermostats... really, Nest?! I mean, for $40 I had higher expectations..
    • That's it. Thanks for reading! Post comments if you have any questions or suggestions
Forest
131 reputação
Autoria de 1 guia
Good teardown report.
However, I think the orange part in Step4 should be Murata 2x2mm RF switch connector, which can be used for RF testing.
Not U.FL antenna connector, which is mainly designed to connect antenna.
Vitexia Gan - Responder
Nice catch :)
I’ve updated the description, thanks!
Forest -
Please take pictures of both sides of all the components,eg front case ,back case, that’s important!thank you!
baozitao@gmail.com - Responder
Visualizar Estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 34
Últimos 30 dias: 156
Todo: 2,260
