Ferramentas utilizadas neste teardown
Introdução
I've had this since I was 3, I think. Anyway it plays cassette tapes and IT HAS A MICROPHONE!!!! ooooooo!
The model nunber is TCM-4500
It was first introduced in the 1980's
Here we have a 'my first Sony' cassette player with a microphone
It can even take a second microphone, sold seperately of course
Main microphone plug
Secondary Microphone plug
This model uses four C-cell batteries, these have been in here since I was 10, hmmm... wonder if there's any juice left?
Time to take the batteries out
Push down at one end of each row of batteries towards the spring
With the tension released pull out on the battery until it comes out
Repeat until all four are removed
Thumbs up to Sony for providing nice visual instructions for those kiddies
To remove the red back cover you need to remove six screws placed around the border of the cover. Note! The bottom 2 screws are longer than the other 4. These 2 are 35mm long whilst the other 4 are only 30mm long. Don't mix them up !
And voilà! Now we have a nice view of all the internal components
Remove one screw to take off the rear part of the carrying handle
We also gain access to the rubber microphone holder
To remove the speaker first you'll need to get some slack on the wire, do this by pulling it out of a plastic holder thing
Proceed to to lift up the blue chassis and remove the four screws holding the speaker down
It was a bit of a fight but I was able to pull the blue chassis out of the front piece of the red case
There were no fasteners holding them together
Take out three screws to remove the main circuit board
Then unplug four sockets attached to the circuit board
And here we have the only circuit board in this device, don't see any big processors on it, I guess I can't turn it into a super computer :(
After unplugging the circuit board we can completely remove the speaker
It packs a whopping 3 1/2 inch speaker
Remove four screws to loosen the tape drive chassis
Then pull up and back to take the chassis out
With the tape drive chassis on its own we can look at Sony's weird button system, we also have the blue chassis with no components on it
Take out two screws to remove the tape reader/writer
To take the microphone apart just pull very hard on the red handle and it will come out, its held on by two tabs
Take off the yellow cover by wedging a flathead screwdriver in the crack and prying it off
Now we can look at a little microphone, and surprisingly it even has its own windscreen
So here we have it all disassembled, and THERE WERE NO 'WARRANTY VOID' STICKERS ANYWHERE!!!
Um comentário
Do you know where I can find belts for this device? I need both belts new.
