Ir para o conteúdo principal
O que você precisa
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua Motorola V3i, use o nosso manual de serviço.
  1. Motorola V3i Teardown, Motorola V3i Teardown: passo 1, imagem 1 %32
    • A Motorola V3i!
    • Let's see what's inside...
  2. Motorola V3i Teardown: passo 2, imagem 1 %32 Motorola V3i Teardown: passo 2, imagem 2 %32
    • Let's turn it and take out the battery.
    • Remove these two screws.
  3. Motorola V3i Teardown: passo 3, imagem 1 %32
    • Now you can easily flip the cover.
  4. Motorola V3i Teardown: passo 4, imagem 1 %32 Motorola V3i Teardown: passo 4, imagem 2 %32 Motorola V3i Teardown: passo 4, imagem 3 %32
    • You need to detach these two plastic lashes from the surounding.
    • Now you can remove this transparent plastic case.
    • Now you can take out the speaker.
    • The metal thing on the end of the picture is the antenna.
  5. Motorola V3i Teardown: passo 5, imagem 1 %32 Motorola V3i Teardown: passo 5, imagem 2 %32
    • So, that's the board.
    • Vibra motor.
    • Mini USB.
    • Connector for the antenna.
    • After I took these EMI shields away it looks like this...
  6. Motorola V3i Teardown: passo 6, imagem 1 %32 Motorola V3i Teardown: passo 6, imagem 2 %32
    • Bluetooth chip by Broadcom.
    • 32Mbit PSRAM by STMicroelectronics.
    • Baseband Processor (Main Processor) by Freescale (90nm structure).
    • RF Transmitter by RF Micro Devices.
    • Battery controller by Freescale.
    • Quad-Band Transmit Module by RF Micro Devices.
  7. Motorola V3i Teardown: passo 7, imagem 1 %32 Motorola V3i Teardown: passo 7, imagem 2 %32
    • Remove these 4 rubbers.
    • Then remove the four torx screws.
    • You can easily lose these rubbers. (That's why I have only 3 of them...)
  8. Motorola V3i Teardown: passo 8, imagem 1 %32 Motorola V3i Teardown: passo 8, imagem 2 %32
    • Filp the device and you can remove the top housing.
    • Remove the three buttons on the side of the device.
    • Remove the connector to the mainboard...
    • and to the camera.
  9. Motorola V3i Teardown: passo 9, imagem 1 %32
    • Remove the camera by lifting it up.
    • That's a 1,3Mpix camera!
  10. Motorola V3i Teardown: passo 10, imagem 1 %32 Motorola V3i Teardown: passo 10, imagem 2 %32 Motorola V3i Teardown: passo 10, imagem 3 %32
    • Lift up the speaker.
    • Then, that's a tricky part,remove all the buttons around the screen housing. Caution: They are really thin and they easily break!
    • After you did this tricky part you can lift the top of the phone away.
  11. Motorola V3i Teardown: passo 11, imagem 1 %32 Motorola V3i Teardown: passo 11, imagem 2 %32
    • Now lift up the front glass from the top of the device. It's held with adhesives.
    • After you did this it should look like this.
  12. Motorola V3i Teardown: passo 12, imagem 1 %32 Motorola V3i Teardown: passo 12, imagem 2 %32
    • Around the screen there are some lashes. Detach them to release the screen of the metal housing.
    • Then you can lift the metal housing up.
  13. Motorola V3i Teardown: passo 13, imagem 1 %32 Motorola V3i Teardown: passo 13, imagem 2 %32
    • The metal housing is very fragile!
    • an ATI Imageon chip! It's a mulitmedia co-processor, it is used for record video and mobile gaming. It support up to a 2Mpix camera.
  14. Motorola V3i Teardown: passo 14, imagem 1 %32 Motorola V3i Teardown: passo 14, imagem 2 %32
    • Again there's a small lash on the botton of the front screen housing.
    • After that you can remove the front screen with the PCB.
  15. Motorola V3i Teardown: passo 15, imagem 1 %32
    • The front screen.
    • Yes, my front screen has some dead pixels. (They are pink?!)
  16. Motorola V3i Teardown: passo 16, imagem 1 %32
    • Thank you for reading my Teardown:)
Peddy
Membro desde: 12/28/09
159 Reputação
Autoria de 2 guias
Um comentário
Have an old V3i and the screen has just stopped working - have a feeling it’s become disconnected, is it work tearing it down like this to try fix the problem? Want it still to work after though
Iala - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 17
Duração total: 24,626
