Ferramentas utilizadas neste teardown
Introdução
Wanna know how to disassemble Motorola Moto X Force? Here show detailed steps.
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua Motorola Moto X Force, use o nosso manual de serviço.
  1. Remove it or it will be a barrier to remove motherboard. Remove it or it will be a barrier to remove motherboard.
    • Remove it or it will be a barrier to remove motherboard.
  2. Use heat gun to heat up back cover firstly. Insert metal opening tool to open a gap and cut adhesives around. Insert metal opening tool to open a gap and cut adhesives around.
    • Use heat gun to heat up back cover firstly.
    • Insert metal opening tool to open a gap and cut adhesives around.
  3. Use tweezers to cut adhesives underneath. Use tweezers to cut adhesives underneath.
    • Use tweezers to cut adhesives underneath.
  4. Twist off 17 screws by T3 Torx screwdriver. Take away rubber bracket securing NFC antenna and release NFC antenna connector. Take away rubber bracket securing NFC antenna and release NFC antenna connector.
    • Twist off 17 screws by T3 Torx screwdriver.
    • Take away rubber bracket securing NFC antenna and release NFC antenna connector.
  5. Take away rubber bracket securing MIC flex and release microphone flex cable connector. Take away rubber bracket securing MIC flex and release microphone flex cable connector. Take away rubber bracket securing MIC flex and release microphone flex cable connector.
    • Take away rubber bracket securing MIC flex and release microphone flex cable connector.
  6. After middle frame's separating from the rest of parts, side buttons are loose and easy to remove.
    • After middle frame's separating from the rest of parts, side buttons are loose and easy to remove.
  7. Release MIC connector. There are adhesives existed underneath. There are adhesives existed underneath.
    • Release MIC connector.
    • There are adhesives existed underneath.
  8. Use tweezers to pry this part up. Use tweezers to pry this part up.
    • Use tweezers to pry this part up.
  9. The vibrator is only fastened by the plastic bracket. The vibrator is only fastened by the plastic bracket.
    • The vibrator is only fastened by the plastic bracket.
  10. Free shipping on all orders over US$100 or containing a Pro Tech Toolkit!
    Visite Nossa Loja
  11. There are a little bit adhesives around, but you can peel this part easily. There are a little bit adhesives around, but you can peel this part easily.
    • There are a little bit adhesives around, but you can peel this part easily.
  12. Pry this part up. Pry this part up.
    • Pry this part up.
  13. Peel off the tape. Twist off 2 screws. Twist off 2 screws.
    • Peel off the tape.
    • Twist off 2 screws.
  14. Release this two connectors carefully.
    • Release this two connectors carefully.
  15. The LCD assembly has two connectors, here is touchscreen connector. The LCD assembly has two connectors, here is touchscreen connector.
    • The LCD assembly has two connectors, here is touchscreen connector.
  16. This one is display connector. This one is display connector.
    • This one is display connector.
  17. Release signal cable connector. Pry the motherboard assembly up. Pry the motherboard assembly up.
    • Release signal cable connector.
    • Pry the motherboard assembly up.
  18. Moto X Force packs a 21-megapixel primary camera on the rear. Moto X Force packs a 21-megapixel primary camera on the rear.
    • Moto X Force packs a 21-megapixel primary camera on the rear.
  19. Use tweezers to release the connector. Use tweezers to release the connector.
    • Use tweezers to release the connector.
  20. With this sensor flex, you can wave your hand on the top of the screen to wake up the screen. With this sensor flex, you can wave your hand on the top of the screen to wake up the screen.
    • With this sensor flex, you can wave your hand on the top of the screen to wake up the screen.
  21. Non-removable Li-Ion 3760 mAh battery. Non-removable Li-Ion 3760 mAh battery.
    • Non-removable Li-Ion 3760 mAh battery.
  22. A 5-megapixel front shooter for selfies. A 5-megapixel front shooter for selfies.
    • A 5-megapixel front shooter for selfies.
  23. Be careful to pry this part up, because it tends to fall apart easily. Be careful to pry this part up, because it tends to fall apart easily.
    • Be careful to pry this part up, because it tends to fall apart easily.
  24. Use tweezers to cut adhesives underneath. Use tweezers to cut adhesives underneath. Use tweezers to cut adhesives underneath.
  25. Here is LCD screen with LCD supporting frame. They are attached tightly, so we haven't separate them. Here is LCD screen with LCD supporting frame. They are attached tightly, so we haven't separate them.
    • Here is LCD screen with LCD supporting frame. They are attached tightly, so we haven't separate them.
  26. Done.
    • Done.
Witrigs
60.727 reputação
388 Guides authored
amoled
Danila Elchin - Responder
Good afternoon,
Tell me what you can say on the problem faced by many users of the device.
When you connect the original or third-party charger with fast charging Functions or without fast charging function, and sometimes when using cordless phone charging on the charge indication is presented but charging rate is 1-3% per hour. This problem occurs on the Droid Turbo 2 and X force.
I would like to hear your opinion on this issue.
Vikulov Aleksander - Responder
Several units are plagued by a vertical green line that appears on LCD (just search for Moto X Force or Droid Turbo 2 Green Line). Bad flex or bad LCD ?
NCQ - Responder
There should be problem of lcd screen flex.
Witrigs -
I have a UK Moto X Force. I have noticed that the green line appears when You push harder between the screen and right loudspeaker hole. it disapears when I remove my finger. I hope this green line wont become permanent :/
Dxt D -
Does this tutorial works with Moto X Play?
werther - Responder
can i use droit turbo 2 logic board on moto x force? i whant to change logic board becous my is crashed
sandro bitarishvili - Responder
:) Several very odd responses to this teardown, so I'll be the first to say.....
Thanks very very much Eric and other contributers, for taking the time to leave this guide. It's perfect and helped me get the thing apart without killing it - aint they a pain when they keep turning back on? I just want to mention thsi one extra bit.....
Be careful when prizing the back off the phone, it stuck so well on the one I've just done (even though I've fixed dozens of phones and am very familiar with the 'heating up' process to soften the glue, well in fidlling about with it, I was horrified to see I'd pressed the buttons in just the right way to get it to boot into its RECOVERY menu, and one more button press would have erased the customers contents!! *gulps*.
This happened despite the fact that the phones battery has been so flat it could never turn on beyond showing the Flat Battery logo - still had enough power to get into Recovery LoL.
Many thanks again Eric :-)
assortedrubbish - Responder
Hi, i bouth a Motorola x force, and i have a problem with the dual sim, the sim 2 does not work as a sim, but work when i use with a memory card.- Thank you!!
Juan Diego - Responder
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 44
Últimos 30 dias: 172
Todo: 15,502
