Introdução
This guide is for educational purposes and should not be used as a repair guide.
O que você precisa
Place your thumb in the indent located at bottom left corner of the back cover.
The cover will pop up and begin to lift.
Continue to slide your fingers up the sides to remove the back cover.
Using the tweezers, pull up on the clasp that is holding the motherboard down.
Using the tweezers, pull up on the clasp that is connecting the motherboard to the front-facing camera.
Using the tweezers, remove the red and black wiring from the bottom of the phone by the charging port.
