Introdução
The Droid RAZR is here, calling upon state-of-the-art space-saving technology, as well as a bit of nostalgia. Claiming once again to have made the thinnest phone in the universe, the Droid RAZR touts impressive features packed into one package. For safety reasons, we will not be throwing it around to see if it will cut bikes and lamp posts (as its trailer suggests), or shooting it to verify if it's bulletproof (we know it's not) -- but we will be opening it up to see what gives it its phone, video, audio and gaming powers.
Do these teardowns blow your mind and you can't get enough of them? Follow @ifixit on Twitter to stay up to date with the latest teardown shenanigans.
O que você precisa
Is it Christmas already?? No, it's not even Thanksgiving, but we've already received a gift from Motorola—the Droid RAZR. The newest and thinnest addition to the dual-core Droid lineup, the Motorola Droid RAZR packs some impressive specs:
1.2 GHz dual-core processor
1 GB RAM
16 GB internal storage + 16 GB microSD (expandable up to 48 GB)
4.3" Super AMOLED display with Corning Gorilla Glass
8 MP with HD video recording (1080p) rear-facing camera
Verizon 4G LTE network capability
We have heard some mighty claims about the thinness of this phone, but how thin is it really?
Oh ... that thin. The claims are true; this phone is pretty darn thin.
The RAZR measures in at a mere 0.28 inches thin and increases to 0.42 inches at
its love-handlethe prevalent Motorola camera bulge. -
There is no doubt that the Droid RAZR is exceptionally thin, but Motorola had to fit the internals somewhere. To compensate, the RAZR is also rather large, measuring in at 5.15 inches long and 2.71 inches wide.
The micro-USB and micro-HDMI ports are located at the top of the phone, next to the 3.5 mm headphone jack.
Motorola likely chose this spot because the rest of the phone's slim profile would not be able to fit the ports.
Looking at the rear of the phone gives us a glance at the 8 megapixel HD camera and Kevlar rear cover.
The Droid RAZR contains an LTE SIM Card slot and a microSD card slot, hidden inside a secret compartment.
The phone ships with a pre-installed 16 GB microSD card (for some carriers), for a total capacity of 32GB of storage. It supports microSD cards of up to 64 GB.
This is how the Droid RAZR stacks up to the Nexus S and the original Droid.
And when compared side-by-side, the Droid RAZR is clearly thinner than the iPhone 4S. However, the RAZR sports a much larger footprint that may make operating the phone difficult for folks with smaller hands. More on that later.
Here we show the Droid RAZR next to the original Motorola Droid. The extra half inch in either direction makes for a slightly awkward feel when holding the phone in one hand.
Ferramenta utilizada nesse passo:Spudger$3.99
The back cover is fastened tightly to the rest of the phone; removing it will be no simple task. If only we had another Droid RAZR to help slice this one open...
Having only one RAZR, we were forced to improvise. This task called for nothing less than... a dozuki.
With a little finagling, the back cover separates from the rest of the phone, exposing the battery and the cool Kevlar weave.
How can something that provides so much rigidity bend so much? The thin plastic, mated with the woven Kevlar, provides a tough yet flexible back cover. With the tensile yield strength of Kevlar being on par with some steels, the back case is the least of our worries as far as critical future repairs go.
After twisting and contorting the back case, we shift our focus to what its removal has exposed.
A flick of our spudger, a twist of our T5 torx screwdriver, a click of our heels, and badabing badaboom—the battery's disconnected.
It's quite the ordeal for removing the battery, but at least you don't have to rip the entire phone apart like a certain other phone we know.
Instead of the traditional battery connector socket or soldered wires found in other phones, the Droid RAZR utilizes contact points for its battery connector.
With the battery no longer firmly attached to the phone, all we have to do is pull the handy "remove battery" tab—ironic, since allegedly the battery's not supposed to be user-replaceable. Oh well.
Measuring in at 3.79" long, 2.25" wide, and .110" thick with a capacity of 1750 mAh, this battery provides over 300 mAh more capacity than that of the iPhone 4S.
For those faithful repair enthusiasts who are still rocking the original 2004 Motorola RAZR V3, the Droid RAZR has a 1070 mAh greater capacity than its great-grandfather.
The battery is ultra-thin, taking up less than half of the phone's total thickness.
The battery capacity comparison with the iPhone 4S misleading; you can't compare mAh from batteries with different output voltage. A battery with the same mAh rating and twice the voltage output would have twice the energy capacity - just like when you put two batteries in series.
For a fair comparison the mAh should be multiplied with the voltage output which will make it mWh. So to compare both, the iPhone 4S has a 5291 mWh battery and the Droid RAZR has 6650 mWh, making it a 1359 mWh difference.
What we had once called a forest of EMI shields has now met its match. The Droid RAZR boasts an Amazon Basin's worth of EMI shields impeding our progress.
With the help of our T5 screwdriver, we twist out a few screws from the aluminum and plastic frames still covering the motherboard.
T5 screwdriver is too big for these screws. There are two sizes of screws. T5 for batterie connect OK but some are smaller.
T5 for the battery, the rest of the screws are T4.
malken01 -
We were prepared to remove the rear inner framework when suddenly our super iFixit senses detected a hidden screw!
We peeled off the plastic cover from around the rear-facing camera to reveal a hidden screw near the flash LED. Sneaky, sneaky Motorola.
Dispatching that mischievous screw, and disconnecting several small clips around the perimeter of the rear inner framework enabled us to remove it from the motherboard and display assembly.
Ferramenta utilizada nesse passo:Coin$2.99
A few more Torx screws, and we're able to remove the diamond-cut aluminum chassis.
Why diamond-cut? Motorola needed ultimate precision when manufacturing this thin and light weight component.
How extreme are the space constraints inside a device this thin?
From the bottom to top, you can see the glass, display, motherboard, motherboard chips, and then quarter. (Quarter sold separately)
Pulling back the 1.3 MP front-facing camera, apparently capable of 720p HD video, we are now able to undo all the connectors.
Zif-a-dee-doo-dah! Zif-a-dee-day! Yes, those are all ZIF type connectors, and yes, they all must bite the dust.
Ah, so that's the reason the RAZR is a bit
fatheadedtop-heavy. The larger rear-facing camera boasts 8 MP still picture capability and 1080p video at 30 fps. -
Trying to take video in a fast moving or high vibration environment? Sacrifice a little resolution, down to 720 x 480, and pick up your frame rate to a blistering 120 fps to keep the blur down.
The rear-facing camera is marked as V927ABB.
Is it ironic to take a picture of a camera? We don't think so... This dinky metal box is the 1.3 MP front-facing camera, which houses the lens and circuitry.
Maybe the leopard print on both the front and back camera cable is to help keep the connector somewhat cool(during use) but not to the point of weakening the cable?
I think it's there to make the cable more flexible where it needs to be.
cityzen -
What's that? I can't hear you—speak up. Oh, you're the ear piece, I see. Well, I'm sorry, you're going to have to come out too.
For those itching to reveal their love of Britney Spears new album or Justin Beiber's new hit solo, fret not, this tiny litte speaker packs enough power to resonate [tinny, muddled] music throughout the room.
Holy cannoli! Look at all 'em chips! To keep the design svelte, Motorola packed pretty much everything on one side of the mobo. Let's see what we're dealing with:
Toshiba THGBM4G7D2GBAIE 16GB EMMC Flash Memory
Samsung K3PE7E700M-XGC1 4Gb LPDDR2 RAM
Qualcomm MDM6600 Dual-Mode Baseband/RF Transceiver
Qualcomm PM8028 Power Management IC
Avago ACPM-7868 Quad-Band Power Amplifier
Motorola T6VP0XBG-0001 (believed to be the LCM 2.0 LTE baseband processor)
Texas Instruments WL1285C Wilink 7 Bluetooth/Wi-Fi/GPS
step 18, 19, 20: which of these lovelies hold my photos & videos? hoping to rescue them from a phone that took a toilet dive.
If you find out, please let me know as I want to buy another, with a good screen and led fused glass, and just switch the insides to retrieve photos? Our first child was born and these are all of those pictures, very important to us. My wife be be forever happy if I can pull this off.
I dipped into a jaccuzi with my droid razr in my pocket, for about 30 seconds before i realized it was in my pocket. I put it in rice which didn't help. I then used the above to take the back cover off, I am now going to buy the T5 and T4 torx so I can take battery out. I have insurance and can easily get the phone replaced but just came back from a cruise and have tons of pictures on internal memory of phone, and hoping to salvage so I can at least get my pictures. Any advise on what to trouble shoot first? Note: When i plug phone into wall charger (usb cable into adaptor to wall), the white flash on front comes on for a split second. However when I plug phone using the usb cable to a laptop, the same flash light stays on steady for as long as the phone is plugged in. Any advise is much appreciated.
For the wall charger. Is it the original moto charger that comes with the phone?
heroxbd -
So many chips…where's the dip?:
Skyworks 77449 Power Amplifier Module for LTE/EUTRAN Bands XIII/XIV
Toshiba Y9A0A111308LA Memory Stack
ST Ericsson CPCAP 6556002
Hynix H90H1GH51JMP (similar to other devices we've seen, this POP chip sits on top of the TI OMAP 4430 processor)
Infineon 5726 SLU A1 H1118 3A126586
Bosch 2133 C3H L1ABG accelerometer
And the back of the board? Even the PCB is stepped with a cavity to recess the flex wrap from back to front. Nothing spared in the pursuit of ultimate thinness.
Nothing of interest on the back side of the Board - there is a step (cavity) in the main PCB to further reduce thickness where the flex goes from back to front ...
In combination with the main board high density technology, this is pretty unique, and a measure of the lengths Motorola have gone to with the new RAZR to make it "geet" thin!
Is the Hynix H90H1GH51JMP the OMAP4?
Yes, just like in the Motorola phones before it and the Kindle Fire after it.
You forgot to add the purple square for the accelerometer (to the right of the red square).
A couple of other interesting features: the vibrator motor soldered directly to the board, and the sound cavity for the speaker, with the hole for the sound to go out through the front.
Good eye! Accelerometer squared.
Wait, where's the SoC? It's got to be somewhere, right? I'm guessing its stacked under another chip... Also where's another 4Gb of RAM? Maybe that Hyinx H90H1GH51JMP has something to do with it.
Take a look at our Kindle Fire Teardown where we pulled the Hynix chip off the board. It's reasonable to assume a similar situation is going on here.
Anyone know what that Infineon chip is?
Teardown update: We discovered some interesting chip changes inside a newer Droid Razr. They include:
SanDisk SDIN5C1-16G NAND flash that replaces the Toshiba THGBM4G7D2GBAIE unit
ELPIDA B8164B3PF-8D-F RAM takes place in the Samsung K3PE7E700M-XGC1 RAM location
Toshiba Y9AOA111418L8 replaces the Hynix H90H1GH51JMP chip that sits atop the TI OMAP 4430 processor
Motorola Droid RAZR Repairability Score: 4 out of 10 (10 is easiest to repair).
Once the battery and motherboard are within reach, replacement is easy—no soldering required.
The "non-serviceable" back was a bit of a pain to remove.
The front panel is adhered to the AMOLED display, so they must be replaced as one expensive unit.
All plastic frames and casing proved to be incredibly tedious to remove, and felt like they would break at any moment.
There are copious amounts of adhesive holding the phone together.
17 comentários
"1 GB RAM"
"Samsung K3PE7E700M-XGC1 4Gb LPDDR2 RAM"
So does it have 1 or 4 Gb of RAM?
4Gb (4 gigabits) = 0.5 GigaBytes. I don't know where the other 0.5 GB is.
cityzen -
another 512MB is on the omap4
yeah, where's CPU!?
imrahil -
Just like other Motorola phones and the Kindle Fire, it lies beneath the Hynix chip.
Adhesive is between the back cover and the battery, between the other side of the battery and the internals and between the bezel that hides the screw. The bezel is very fragile and I broke and scratched mine even though I was *very* careful. Bye bye resale value.
The absolute worst thing is, the motherboard is glued to the display assembly! The mobo is VERY thin, and trying to pry the board off the display assembly is, IMHO, very likely to damage the board. I have done a lot of these repairs, and this phone sucks for serviceability.
The battery is easy enough to replace, but pay a bonafide service to replace your screen. If they screw up the phone, then they are on the hook to buy a new one, not you....
Can you just replace the screen or is the lcd attached to the screen. My screen is cracked but my lcd is perfectly fine i need to know if i have to buy the screen with the lcd or just the screen and how to put it on please help.
I have a RAZR Maxx which was replaced through a 3rd party insurer. They must have sent me a refurbished unit because after about 60 days, the kevlar back has separated from the unit. Can anyone tell me what type of adhesive is used to adhere the kevlar back to the battery and unit?
On my phone, there is a black plastic cover over the screen cable, which is apparently molded to the black middle frame. I am trying to separate the middle frame from the front bezel, but it doesn't want to seem to budge at the top and bottom. I am afraid if I force it further I'm going to break something. Guess I'll take it to Verizon and see how much for a new phone.
I am attempting to replace the USB port., as I have a friend who has the equipment and knowledge to do component level replacement, but it looks like I'm stopping at this stage, cause I can't complete the disassembly.
Is there any way to replace the ST Ericsson CPCAP 6556002 chip on this board? I am planning to buy one from http://www.parts4repair.com/power-ic-for....
I gave my XT910 to the service center and they said that the chip that powers the battery is not working and that's why the phone is not charging at all.
I swapped out the old battery with a new one, still no hope.
The witty comments are charming; however, these guides offer little advice or guidance. You would think with all the effort that goes into the dis-assembly pictures there would be simple advice such as "The logic board is heavily taped to the LCD screen" and maybe what can be done to separate the two?
Less wit and more fact would be greatly appreciated.
"Teardowns provide a look inside a device and should not be used as disassembly instructions." We have a full set of 11 step-by-step repair guides on the Droid Razr device page.
scroto balsamico croccante
